Old 07-23-2006, 08:23 PM
bntii's Avatar
bntii bntii is offline
Rep: 948 Posts: 636
stress in sailboat hulls
Does someone have a good feel for how stress is distributed in a sailboat hull?
I have a hull which shows gellcoat cracking along the hull from rail to waterline from stem to stern. The crazing follows a forward and down pattern at about 65 degrees from sheer. The interesting thing is that the pattern does not vary much along the hull (forward and down). I have noted the band bracing specs for wood hulls as diagonals forward and aft from rail down in a apparent effort to strengthen the 'web' of the hulls vertical plane. It would seem that the glass hull does not need any help in sheer of the web and therefore I am observing gellcoat crazing from some other mechanism?? Perhaps rotation of the hull along the long axis? Or deflection outward as the deck and upper hull is compressed during load cycles?
Old 07-24-2006, 01:08 PM
nero nero is offline
Rep: 112 Posts: 624
Can you post a photo?
Old 07-26-2006, 06:54 PM
Rep: 1623 Posts: 2,343
bntii
can you tell us what the vessel is, what layup is the hull core or solid GRP ?
What kind of use does the vessel get eg ocean boisterous coastal or sheltered ?
It sounds like stress crazing from the movement of the boat and you may need to add bulkheads to stiffen her up. Flexure of plastic hulls is always a problem and some are far worse than others.
Mike Johns.
planing catamaran hulls/sailboat terabika Boat Design 16 06-02-2009 09:20 PM
Stress cracks or gel coat damage? see attachment 75HUSTLER Boat Design 2 06-23-2006 09:13 AM
Stress Cracks cammo Fiberglass and Composite Boat Building 8 09-26-2005 10:25 PM
Who knows hulls b.hernackiAgte. Open Discussion: All Things Boats & Boating 0 09-15-2005 12:49 AM
Four hulls better than two? Wynand N Boat Design 5 03-12-2005 03:46 AM
