Old 01-30-2003, 12:44 AM
kapnD kapnD is offline
Rep: 19 Posts: 142
strange hulls
Ive seen sevral hulls lately, mostly aluminum workboats, that look like normal semi-vee hulls, but with a canoe-like pod underneath running from the bow to the propellor. I'm baffled by the design, whats the idea?
Old 01-30-2003, 11:40 PM
KCook KCook is offline
Rep: 13 Posts: 171
Not a clue. Sounds like the inverse of a tunnel hull though! Can you give us a URL to a photo of one of these things?
Kelly Cook
Old 02-02-2003, 06:52 AM
As Kelly says, is there any chance you can take a digital photo or two and post them, or point to a picture somewhere so we can see what you're seeing? I'm curious...
Old 02-02-2003, 01:31 PM
Zanith Zanith is offline
Rep: 10 Posts: 10
Yes. I wanna see!
Old 02-04-2003, 08:34 AM
jonathan jonathan is offline
Registered
Rep: 10 Posts: 81
And is the prop right behind that thing ? Is it stremlined or does it stop abruptly at the transom ? And what kind of workboats are they, fishing, tugs, diving,... ?
It's true, some sort of picture, or even a schematic drawing would be useful.
Might be some kind of protection, though...
Jonathan Foucher
Marine Technologies Yacht Design
http://www.marinetechs.com/
Old 02-04-2003, 12:50 PM
interlude interlude is offline
Rep: 11 Posts: 20
Could be additional flotation was added after design?
Old 04-05-2003, 11:16 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
You may be thinking of the box keel/sponson designs that Phil Bolger (and others) have been employing. My take: it may make some sense in the semi-displacement speed range.
Old 04-19-2003, 01:00 AM
it's an engine pod. you can reduce the shaft angle this way. I've seen a number of re-fits in the National Fisherman magazine this way
Old 04-19-2003, 04:22 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
This picture is lifted from the site of Conrad Yachts , the designer, Jarek Kanios. I think maybe this is what the question is about. It’s not an add-on, just the result of putting large planning flats at the first chine. As opposed to a box keel, which blends with the stem.
Gary
Old 04-20-2003, 12:12 AM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
wild guess.....
Here in Alaska the salmon drift (Bristol bay region) netters have a waterline length restriction of 32'. So the builders of the new boats are getting creative.(Seattle builders) Most of them are aluminum and resemble a 3 story condo on a jon-boat hull. But the fun part is they will do 20+ knots with 30,000#s on board. Usually twin or triple jets. I have seen bulb type bows on them. Maybe what you are seeing is some new derivitive of this style of workboat seen here in the pacific NW. get some pics if you can.
8Kts
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 07:54 AM
Radius Chine Hulls Inerested Boat Design 7 02-12-2008 08:04 AM
ROCAT closed mould one-piece hulls cristofa Fiberglass and Composite Boat Building 10 07-15-2005 05:13 PM
A Tale of Two Hulls.... BCBoater Boat Design 6 09-05-2003 02:48 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
