| strakes/rails Hi guys, this is a mor "buildish" issue but I didn't have replies in the building forum...so here I am: I will need to put strakes /spray rails (however you want to call them) under a fiberglass hull that will be built with C flex on a male mold. My questions are: When should I put them in? after the C flex has cured and then cover them with regular lamination? After the entire lamination is done? What's the strakes building method? Do I start from a straight batten triangular in section? Thanks for your help, federico |
