Old 11-08-2003, 11:30 AM
strakes
Hi, I have a 16'4" dual hull hand made fiber glass boat made almost 30 years ago. The transom is 12 inches narrower than the bow. The aft hull narrows and becomes a flat bottom. I have added flotation and deching; center consul and forward trolling motor snf carry extra fuel in the aft section. When I am alone the boat planes in about 15 seconds, when one more adult as aboard the plain takes forever. The weight is aprox. 1,100 lbs. Recently I added a 65 hp outboard replacing my Merc 25 xp. The boat flies now however takes a minute or so to get on plane with the extra passenger. The hull has no strakes. I am considering trim tabs or speed rails. What do you suggest? Thanks in advance, Sid
Old 11-08-2003, 12:41 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
iff you can pull it i would say make it trim tabs AND speed rails. the tab's may be the best of the two to get on plane quiker with the extra passenger.
strakes ARGO Powerboats 19 07-21-2005 07:34 PM
Strakes ARGO Boat Design 1 05-15-2005 06:08 PM
Very deep V with strakes or progressive V jfblouin Boat Design 13 02-09-2005 02:17 PM
Need help on designing stepped forward-vented bottom hulls with staggered strakes Trimix Education 0 09-16-2004 04:13 PM
Need help on designing stepped forward-vented bottom hulls with staggered strakes Trimix Boat Design 0 09-15-2004 01:15 PM
