| Strake for 14 ft Aluminum I have a project that's been waiting for a few years. I think the boat is mfg. by Lund and approximately 50 year old. The original wood strakes are shot. But I have not found any replacements that would seem to work. ![]() |
| I dont think the strakes are OEM, probably added by some previous owner. Why not replace them with same? If not, a fiberglass or aluminum 2x2 angle could be used to eliminate the rot problem, maybe get another 50 good years out of her! |
| I like your idea of staying with wood. Do you have any suggestions of type? I was thinking that oak might work. |
| Well, in MONTANA this is a strake!! A spray strake. OK aluminum is back on the table. |
| to see water climb do a simple test with a big spoon and a gentle stream of water coming out of a tap Hold the back of the spoon just against the stream of water about 6 to 9 inchs away from the tap !You will see the water will almost go all the way round the back of the spoon till it reachs the sharp corner where it will let go and fall . To make a inflateable boat go fast you need to get the tubes out of the water because it will climb quite a long way up the side of the tube , apart from water drag friction it adds weight and holds the hull to the surface of the water . ![]() |
| Oak would be good but heavy. This is not a strake. It's a rub rail at the dock and a spray rail while underway. But mostly a spray rail as Tunnels suggests. And it's not too big. Many soft chine boats of the 50s had them. It should be laminated from several pcs of perhaps Douglas Fir. Use the hull as a form perhaps. Use resorcinal (sp?) glue for lam. I don't know how to attach it though. Screws and fender washers I spoze but would take many. Nix on alum angle ..look like Wall-Mart and prolly bend and never be straight and look right again. When aluminum manufacturers but them on they used a tapered and flanged angle but the two edges of the angle was riveted to the boat. I think thats only a factory option and capability. Those Lunds are all over the place up here and I don't think Iv'e ever seen one w an wood spray rail. Could really be 50yrs old! Easy Rider |
| Thanks for all the input. I will let you know how the spray turns out! |
| Chine and strake design | meren | Powerboats | 45 | 06-01-2010 10:48 PM |
| Carolina Fender Strake | yellowfinii | Boat Design | 6 | 03-05-2010 09:44 AM |
| Spray strake arrangments | Brooks Dees | Powerboats | 2 | 12-04-2009 08:50 AM |
| Lifting Strake Construction | WoodenPontoon | Boat Design | 20 | 11-23-2009 09:54 PM |
| Radius of strake and chine | jfblouin | Boat Design | 0 | 10-13-2005 10:33 AM |
