| Stoned Pirates first hull Hello, Pirate again with more 10 foot circumnavigation madness. Started designing my hull for real and will start building it as soon as she's designed to perfection. I am taking the keep it simple approach. I need a bulletproof 10 foot hull that can provide enough space for 100 days worth of provisions plus me. My first hull is inspired by phil bolgers approach, using simple ply board with nothing fancy. Its a brick like the micro without the flat bottom. Is it too tall? That blue thing is a 6 foot guy my size. ![]() ![]() ![]() ![]() ![]() |
| It will have a lead ballast keel. What are the downsides to having straight, box like vertical chines? |
| Heres the max file. Any constructive critisism appreciated ![]() |
| I have been reading all the rantings and ravings and what could be construed as negative stonedpirate your complete lack of understanding of the subject matter and your complete lack of sailing experience screams out loudly that you dont have a clue what going on please take this as a positive step to actually help you start reading LOTS AND LOTS MORE Principles of Yacht Design - Larsson and Eliasson Undedrstanding Boat Design - Ted Brewer I am 100% passionate about small boats and mine is coming along just fine so educate yourself first and then go for it Small Sailboat Adventures Building Methods Manie's Shiny Dinghy Small sailing boats - GOOD READING MiniCAT-5 Around in Ten The build part 1 and last but not least Manie's Microcruiser i have a current skippers license and i really enjoy long distance sailing ALONE and a 5m boat is big enough i am not interested in breaking records OR to earn some stupid badge or title = smallest this or smallest that
__________________ Bye bye Folks - off to see the world ~~~/)~~~ :) Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ http://www.boatdesign.net/forums/boa...ser-27869.html |
| So whats wrong with my hull? Am making a balsa model of it. I think with 10 foot hulls, shape is largely irrelevent. They are essentially bathtubs and boauncy, strength and space is the name of the game. A simple hull like this will probably work. Ironically, i got the idea for it from the around in ten guys in the first place. ![]() |
| Here is bolgers micro. ![]() The responses i hear about it are that it is ugly but sails surprisingly well. The only complaint is that its flat bottom creates a rough ride so i added a v and she's good to go ![]() This looks like the simplest hull out, gives heaps of space, easy to build and if it sails half way decent i'm building it. |
| Manie knows his stuff when it comes to small boats and Bolgers are sharpies are they not flat bottoms if you change it to a v its sailing characteristics are completely different just a thought if you loose the desire for a record you could easily realize this plan and be a lot more comfortable in the process B
__________________ I am skeptical of the deniers diatribe |
| Screw sailing around my local neighborhood in the ugliest cheapest looking ply box on the water ![]() If i just wanted to mess about in my protected waters i would just buy a trailer sailor and be done with it. Going bluewater ![]() As for changing its sailing characteristics, i will see how the model performs. WHo knows, this could be the latest thing in hull design haha |
| SP what displacement and draft are you aiming for you don’t show a waterline or is the xyz where its at. |
| Pretty much. Fully loaded i'm looking at between 500-600kg including the weight of the boat itself. LOA and LWL is 10ft. |
| I like crazy ideas. Here is a sketch of the idea I have mentioned in the other thread: A kite powered upside-down simmetric planing hull. It is just a rough estimate of overall shape: I guess the keels should be more pronounced and the area between them more flatter. |
| SP what is the waterline beam and the draft. That dead rise could be a bit much for your weight estimate. |
| Interesting kite idea. The same thing was tried on the around in ten forum. he built it but said it didnt work as well as he hoped. Think it was the flying bear or floating bear. Waterline beam is 1.52meters. Draft depends on how long i make the keel. 85cm to the base of the hull. So probably 1.2meters. |
| SP with those dimensions , dead rise and waterline placement, I think your displacement of the hull design is a little higher than your estimate. |
| Maybe. the V alone is 0.6m^3 I will see what the volume of the main section is. |
| Dealing with pirates | dave L | Open Discussion: All Things Boats & Boating | 1924 | 06-07-2010 07:17 PM |
| Pirates? | Mr.Pirate | Open Discussion: All Things Boats & Boating | 354 | 01-19-2009 03:18 PM |
| Somalian Pirates | Boatpride | Open Discussion: All Things Boats & Boating | 14 | 12-03-2008 09:40 AM |
| Pirates of the Caribbean | Mikey | Open Discussion: All Things Boats & Boating | 17 | 05-23-2007 08:29 AM |
| Pirates! | YarPirateSteve | Sailboats | 23 | 10-30-2005 04:02 PM |
