Old 05-02-2009, 08:50 AM
rickthorn rickthorn is offline
Rep: 10 Posts: 20
Stirling Engine Designs
I was just wondering if anyone had ever considered the Stirling Engine concept for marine designs. Something like solar heat collection above deck and some combination of keel and cooling fins down low in the water (drag would be a definite problem though).
Unless very careful attention were used in developing the initial design, benefits probably would not be justified because of many drawbacks, especially amount of power produced and significant drag.
Old 05-02-2009, 11:01 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
we just went over this is the high torque engines thread
also in the steamless steam engines thread
was a fun study
Old 05-02-2009, 12:04 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Definitely plausible.
Not necessarily efficient, though. The problem with a solar-heated Stirling is the available temperature rise. The Stirling cycle has the same theoretical maximum efficiency as the Carnot (1-Tc/Th) and can, in practice, easily reach about half this value. But it's really, really hard to get much more than 100 C from solar heat unless you have some fairly substantial concentrator arrays. When you run the numbers on that, even a pretty good solar Stirling is only about 12 to 15 % efficient, and ends up being darned heavy to boot. Since solar photovoltaics are lighter, simpler and cheaper than a big Stirling with concentrators and all that jazz, there's been very little economic or technical motivation to pursue solar Stirling power for mobile applications.
The solar Stirling does hold much more promise for land-based applications where large concentrators, and thus substantial temperature differentials, are feasible.
Old 05-02-2009, 12:14 PM
Boston's Avatar
how about a Stirling powered car
http://www.thedailygreen.com/living-...tirling-461108
came out about 6 months ago with a test model that they claim will be commercially available in about 2 more years
Old 05-05-2009, 06:33 AM
Rep: 10 Posts: 20
Thanks for your replies...
The Stirling was something I just wondered about, especially from a "free" energy point of view. Since it's operation is based on temperature difference, it seems like the air conditioning could be worked internally into the system perhaps.
Initially the flying wing was unsuccessful because of it's instability, this was later overcome with the use of flight computer systems. I think there are many, many old designs which should be revisited with todays technologies in greatly advanced propulsion systems, better and lighter engine technologies and the use of composites to reintroduce the ideas in an updated way.
The recent fuel problems in the West will eventually be a blessing in disguise
because of the many new engines and engine advancements that are currently appearing.
From a V-? engine to a 4 cyl.... building the front engine pad sikpupy Fiberglass and Composite Boat Building 0 06-10-2008 08:39 PM
Inboard Engine to Automobile Engine Conversion ?'s Stingray230 Gas Engines 2 09-26-2007 06:04 PM
140 mercruser engine c.i.d. identificafion by engine serial number ggsimpson Gas Engines 0 11-18-2006 10:39 AM
Replacing an outboard engine with an inboard engine boere Sailboats 1 09-16-2005 07:49 AM
Replacing an outboard engine with an inboard engine boere Boatbuilding 0 06-23-2003 04:21 AM
