Old 12-17-2010, 11:22 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Sterndrive Transom Plate For Aluminium Boats
Would anybody have some pics / drawings / info on how the transom plate is typically setup in an aluminium boat? Clearly, you don't use 55mm plate!!
I've attached a pic which just shows the transom plate template extruded to the required thickness, but I'm sure this isn't how it's typically done.....
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 12-18-2010, 04:13 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Two pieces of 24 mm plywood, several coats of epoxy resin until you're sure the surface is completely sealed, then bed it with Sikaflex.
That's the way I would do it.
Old 12-18-2010, 12:02 PM
Rep: 1493 Posts: 7,447
All the ones I've seen have two layers of 3/4" ply with an aluminum skin on the inside.
Old 12-18-2010, 02:54 PM
Hmm - ok... no brackets etc back to the engine beds etc?
Will
www.imaginocean.net
Old 12-18-2010, 03:52 PM
The engine beds usually end up at the transom, just like on a wooden or fiberglass boat. The engine beds are welded or riveted to the bottom and transom.
Old 12-18-2010, 05:14 PM
Yes.. I know.. sorry... didn't explain that very well....
I meant brackets between the engine bed / transom stiffeners etc and the thicker area of the transom where the cutout is
Will
www.imaginocean.net
Old 12-18-2010, 05:59 PM
That depends on how you design the structure. There can be brackets, it can be welded/riveted to the outer or inner skin. You can engineer it in a variety of ways. The beds only have the weight of the engine and torsion. There is no longitudinal forces on them. However, if you think of the hull as a box, attaching the beds or stringer to the transom helps to transfer the torsion load to a transverse member.
Old 12-19-2010, 03:18 AM
CDK's Avatar
CDK CDK is offline
retired engineer
None.
The engine rests on two spring washers on the bracket of the transom housing and one or two adjustable front engine mounts. The load is almost static, just half the engine weight plus some vibration.
The transom has to absorb the thrust as if you had an outboard engine, but the area is larger and lower positioned; I see no problems there.
Transom Hole for Sterndrive oliver.ilg Sterndrives 2 05-16-2009 03:00 PM
plate aluminium boat kit grant1963 Boat Design 14 04-27-2009 02:47 AM
aluminium plate boats daedong Metal Boat Building 6 07-02-2006 04:09 PM
building aluminium boats Kazik Metal Boat Building 4 11-26-2004 04:53 AM
Plate thicknessand other scantlings for aluminium construction Willallison Boat Design 14 05-20-2004 08:11 AM
