Old 09-14-2005, 04:15 AM
Danielsan's Avatar
Danielsan Danielsan is offline
Amateur designer-builder?
Rep: 10 Posts: 229
sterndrive, clearance
Hi to all,
how much space do I need at the transom to mount a sterndrive? Let's say a bravo2 drive
knowing the cavitation plate height falls toghter with the bottom of the hull.
Is it necessary to trim the drive completely up in some case? As this would be my major concern.
have a look at the sketch, if full trim up is not needed, I could make some kind of cavity in the rounded aft part giving me 45 deg left, right and 10-15 deg tilt up clearance?
What clearance is needed to install the drive onto the boat?
Thx
Daniel Peeters
Old 09-14-2005, 07:32 AM
crawdaddy031 crawdaddy031 is offline
Rep: 10 Posts: 15
Full up is not needed as long as you don't mind dragging the drive on the ground when you load onto the trailer or maybe your trailer will be high enough for good clearance when you hit a bump or dip in the roadway. Good luck with your project. Jim
Old 09-14-2005, 10:31 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
While you may never need full-up, it's a good idea to allow enough clearance to do so and to have full steering range when tilted up. I would simply cut out the swim platform in the area around the drive to give it enough room to tilt. I have had many occasions where I have needed to tilt a drive to the top stop- not necessarily trailering, but to get a boat off of logs, sandbars etc. or at docks with low water levels so the prop doesn't hit the bottom when the waves come up.
Old 09-14-2005, 10:50 AM
Danielsan's Avatar
Rep: 10 Posts: 229
Sounds both like enough reasons to get some more room or put the transom more aft then it is now and use some kind of mobile swimplatform to extend the aft part.
Daniel Peeters
Old 09-25-2005, 10:03 PM
DPetersen DPetersen is offline
Rep: 10 Posts: 4
Mercs X dimension (fromthe keel xsom intersection along the transom at 13 degrees to the input shaft centerline) is 14-1/8". Start there.
As for drive clearance, you can buy tilt limiters that go inside the tilt cyclinders. Usually A guy wil have to cahnge a prop int he water and will want it to tip all the way up.
I have used many Bravo 2s in design and installed a new on on my boat. I have a full 3d model of the drive that is accurate and shows the drive int he down position and turned lock to lock and also in the up position. Its handy if you want it write me. Its a Rhino file.
Also, never us a 4 bladed stainless prop. Stick with the aluminum props. It will corrode the paint off of your skeg with or without the mercathode system set up. total BS, another fine problem for the end user from the brain children in Fond du lac. Why make merc cheaper and more reliable when you can add complicated systems that not only ignore users needs, they make it more prone to fail.
Bravo two is the only good merc drive.
Dave
Sterndrive installation Danielsan Sterndrives 14 04-27-2006 08:01 PM
OMC V4 reqiured transom clearance Ozfisher Boatbuilding 1 01-19-2005 07:31 AM
Roach to backstay clearance des Sailboats 1 06-30-2004 07:41 AM
sterndrive for 16 ft powerboat andreirochian Powerboats 11 01-28-2004 10:08 PM
Sterndrive question duluthboats Powerboats 10 08-29-2003 11:12 AM
