| Stepped Hull Resistance Am working on a stepped hull design, LWL 11.7m with twin steps. I have a basis model without steps that when run through savitsky requires 776kW to reach the design speed, however the program give 725 for the stepped model. My concerns are around the program i'm using - hullspeed - and the fact that the manual doesn't state that it can deal with stepped hulls. Not even convinced that Sovitsky is the correct method for stepped hull resistance. Any help/advice would be greatly appreciated. Also pointers towards literature on the matter would be super ![]() Chris |
| not of much practical help but did you read proboat magazine #127 page 56 to 71 with Michael Peters on (fast) powerboats? |
| Transverse Steps Use this excellent paper by David Svahn. It can by extended to two steps. js
__________________ www.sassdesign.net I'm not lost, I'm just uncertain of my position. I'm still confused, but on a higher level |
| stepped hulls Hi all, I'm new in the forum, I've seen a quite interesting item ... , it's since a long time that I''m interested in. It could be interesting to give a look here: http://www.idet.it/idra.html bye |
| Stepped hulls Hey Chris! I am pretty certain that the software Hullspeed does not consider stepped hulls. It also runs Savitsky and the difference you get must be input values... Jurgen Sass: how do you suggest you improve svahn's model to include two steps? I feel some of his assumptions are only valid for a single step, and he said the same thing in a meeting i had with him yesterday. Has anyone managed to model resistance on two steps? How would you predict the wake after the last step? JBS |
virtually it's the same approach: You have to consider each planing surface, delimited by a step, running in the wake of the one foregoing, then compute the equilibrium condition (pitch and heave) for all the planing area together, and force distribution (i.e. 2 steps, 3 planing surfaces), given a Xcg, speed, displacement, it's normally an iterative procedure (in http://www.idet.it/idra.html, that program works up to 4 planing areas - 3 steps, by an iterative method using 3D geometry definition updated each iteration). More steps in the bottom, more local area calcutions must be done, and a bit more complicate to seek global equilibrium. The process must be done by software. Depending on error tollerance wanted, it involves thousands of iteration normally, even for a single speed data. K. |
| Stepped hull | cioko | Powerboats | 11 | 10-16-2011 01:59 AM |
| Stepped Hull wanted! | coast-flyer | Boat Molds | 0 | 07-15-2010 11:24 AM |
| stepped hull | Ryon Macey | Powerboats | 3 | 09-08-2004 10:28 PM |
| Stepped Hull Designer for evaluation of hull | lpsco1 | Powerboats | 2 | 08-18-2002 07:21 PM |
| Stepped hull | micael | Boat Design | 3 | 03-15-2002 02:06 PM |
