Old 11-27-2005, 06:34 PM
garys garys is offline
Rep: 10 Posts: 2
Steering Wheel
I am looking for an expert to tell me what, if there exists, the name or names of the handles on the helm steering wheel. I am hoping they are named something other then "handle". Perhapes a reference to the large steering wheels from the 1400 to 1700's. A reference in an appropriate European language would also be helpful. Any historical information would be helpful, or a different website that could point me in the right direction.
Thanks for your help!
Old 11-27-2005, 08:23 PM
Robjl Robjl is offline
Rep: 10 Posts: 90
I think you are talking about "spokes".
Old 11-28-2005, 08:03 AM
Rep: 10 Posts: 2
I have seen them called spokes, but that is so generic. I have got to believe that there is a more specific name for the actual handles on the end of the spokes. Such as, "I broke my spoke, not the whole spoke, but the end of it where I grab with my hand". That has to have it's own name!
Old 11-28-2005, 10:59 AM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Pins, because the old sailing ships found that a " belaying pin " fit the hand so well.
Old 11-28-2005, 01:05 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
And after careful measuring to ensure that it was square one of these spokes or pins was called the 'king pin' or 'king spoke'. This was the central spoke/pin which indicated that the rudder was 'midships' or square to the hull (had no steering effect). 'Twas normally marked in someway. natural way being to clap a turks head around him tighened up 'ee looked proper 'ansome and could be easily found in the dark. _ typical steering order from an old mate to an old hand when close to the course would be to "give 'er a couple of spokes up wind/down wind" course would be no good to a sprog 'cos he bain't be knowin' what 'ee be talkin' bout!
Old 11-28-2005, 03:55 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
me, i'm not so sure. bout "pins and spokes" nor that "king pin". do belive there must be a marker but most wheels have many cycles to turn. once had a small indicator on the wheel showing how many turns the wheel was star or port. having the "pin?" belayed i think of a rope or string keeping it on course.
Old 12-19-2005, 04:05 PM
hateka hateka is offline
Rep: 10 Posts: 23
In Dutch they are called 'spaken' , one is a 'spaak' close to spokes. The centre one, for rudder midships is called the konings-spaak, or king-spoke. Marked with some brass cap, or turkish knot.
Old 12-20-2005, 12:27 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
I think hateka comes quite close with his reply - a "handspaak" is similar too a belayinmg pin, so that's not the explanation.
I remember, however vaguely, that there is a specific name too........
Old 12-20-2005, 02:09 PM
Rep: 10 Posts: 23
In Dutch the 'handspaak' is also a removable horizontal bar, with a tapered end to insert in a capstan, usually 8 handles in a capstan, in Dutch 'kaapstander' . A Belaying pin, is a removable bolt of the nailbench, 'nagelbank' used to belay a halyard. That bank was around the foot of the mast, only beside, either side or three sides, on the square riggers. The belaying pin is called in Dutch: 'korvijnnagel'. Often used as weapon on board, as the handspaak. Coming back to the handspaak, it is used in two locations, the wheel and the capstan.
Old 12-20-2005, 02:34 PM
Absolutely correct.....forgot to imply that......
Steering systems diazklm Powerboats 2 11-11-2005 04:03 AM
Cable Steering Setup Karsten Weiss Powerboats 7 11-03-2005 07:28 AM
Low power tunnel, low speed drive robrohdeszudy Propulsion 9 12-23-2004 05:09 PM
88 Ski Supreme Steering Problem ew777 Powerboats 2 05-18-2004 05:23 PM
How do you rig wood-spoke wheel steering? Guest Wooden Boat Building and Restoration 1 03-19-2004 09:34 PM
