Old 04-30-2008, 03:04 AM
shaun2222 shaun2222 is offline
Rep: 10 Posts: 3
Steering
Sorry if this is the wrong section, wasnt quiet sure where i should post this question.
I have a small 11ft fiberglass boat that i'm working on. The boat has a 25hp evinrude wacker attached to the back and came with a cable steering system. The system is worked and i want to replace it but i dont want a cable system. I would like to find maybe a rack and pinion system or somthing else that would work. The problem i'm finding is that my dash on this boat is only 3.5" tall and the standard rack & pinion systems from teleflex are too large. Anybody know where i can find steering systems for smaller boats?
Old 04-30-2008, 03:05 AM
Rep: 10 Posts: 3
here's the boat in case it helps at all.
Dash
Old 04-30-2008, 03:28 AM
Previous Member
Rep: 0 Posts: 0
yes a hydrive hydraulic will fit, or most any, prepared spend dough ray me
Old 04-30-2008, 03:34 AM
Rep: 2891 Posts: 8,789
TeleFlex use to make the helm you probably need, but unfortunately they don't any more.
You may have to live with a couple of inches of helm unit hanging below the instrument panel, but from all vantage points except lying on the floor, you'd never notice.
If it's that big a deal for you then go look at TeleFlex part number SH 5210 P, which is a sterndrive setup and may work for you. It uses the SSC 134 cable.
self steering vane bkpatriot OnBoard Electronics & Controls 1 06-03-2007 06:12 PM
Proa steering SeaSpark Sailboats 75 05-14-2007 12:44 PM
Steering Wheel garys Boat Design 9 12-20-2005 02:34 PM
Steering systems diazklm Powerboats 2 11-11-2005 04:03 AM
Self Steering Gear panthablue Sailboats 18 07-09-2005 07:59 AM
