Old 05-02-2005, 08:12 PM
budner1 budner1 is offline
Rep: 10 Posts: 7
Steel to use in a keel strut casting
Hi i was hoping some people with experience could advise me on some trade names for steel with high modulas of elasticity. i'm designing for a uni project a canting keel strut and need more information to finish off my calculations.
thx Peter
Old 05-03-2005, 06:38 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
The steel of choice for carved keels is Dillimax. Do a google and that should turn up all you need.
Steve
Old 05-03-2005, 07:26 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
All steels have the same modulus of elasticity. Some have higher tensile or yield strength. Many of these properties are affected by heat treatment, some are more or less weldable, stainless steels may have more or less corrosion resistance (and some copper bearing steels have slight improvement in corrosion resistance when coated, due to better coating adherence as well as improved strength), and cost is always an issue. What process do you intend to use (theoretically, that is) to build it?
Old 05-03-2005, 12:10 PM
Rep: 10 Posts: 7
l should have been more percise
Maybe not just steel but thinking about cast iron too.
This best theoretical process without cost consideration would be milling to my mind, but keeping cost in mind i'm trying to way up the factors of fabricating or casting. What i was thinking was casting the strut, there for reducing concentrations of stress in sudden changes of sectional area, corners or over welds. As far as i'm aware with the use of heat treated high tensile steel, you lose its a lot of its tensile properties from the heat generated by any welding. Any more information you can advise me on or help me with would be greatly appreciated.
Thanks alot,
Peter
Compromises - Ballast keel? Mohan Pakkurti Wooden Boat Building and Restoration 7 11-14-2005 07:53 AM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 08:55 PM
Keel casting costs/ Carbon Fiber mast Royhunter Boatbuilding 8 02-28-2005 12:41 PM
Altering shoal draft keel? CaptK Boat Design 8 10-06-2003 10:54 AM
