Old 04-08-2004, 09:33 PM
Gerald Niff Gerald Niff is offline
Rep: 10 Posts: 3
Steel sailboat mast
http://dixdesign.com/FAQsteel.htm
Here is a web site that claims steel masts are the hot setup. Can anyone direct me to a site that shows a steel mast being built or information on the building of a steel mast? I still need a mast for my 36' steel mulichine.
Gerald
Old 04-09-2004, 03:32 PM
SeaDrive SeaDrive is offline
Rep: 15 Posts: 223
Brent Swain has done some work with steel masts for his steel boats. You can find some info at the Origamiboats Yahoo:
http://groups.yahoo.com/group/origam...yguid=10611080
You may have to become a yahoo member and a memeber of the group to see what you want.
Peter
Old 04-14-2004, 03:17 PM
Brad Kelneck Brad Kelneck is offline
Rep: 10 Posts: 17
Gerald: I too have a 36' steel multi-chine boat, in a cutter rig and have aluminum spars. I note that the site you highlighted (Dudley Dix), refers to using steel masts on gaff rig boats only. The difference is significant - gaff rigs typically have much shorter masts and therefore the increased weight aloft is less of a detriment. My mast is 45' long and additional weight aloft would have serious impact on stability. That is why people are moving to carbon fiber masts as opposed to aluminum in many performance boats. I would strongly suggest that you go with aluminum. You could build your own with external track, purchase a new one from a manufacturer, or look for a used one that meets your needs.(Believe it or not, there are quite a few out there.)
Brad Kelneck
Old 08-11-2004, 07:03 AM
Rep: 1623 Posts: 2,343
Really whether or not the steel mast is feasable depends on the boat design. In a heavy displacement boat a bit of weight aloft has some advantages.
The inertia is relative to the square of the distance from the axis of rotation. So that heavy weight aloft makes your boat much more stable ...providing the design allows it.
Sounds odd but weight aloft adds to seaworthiness and reduces rapid roll acceleration. Also reduces capsize risk.
Carbon fibre masts are plauged with failure problems and have a terribly low torsional stability....only to be used on plastic surf boards/racing machines.
On seaworthy yachts a steel mast is fine and will often be little heavier than an aluminium one, and lighter than a timber one (remember those days?)
If you have any doubt try and contact the designer, this is cheaper if he is up to scratch, since he should have the weights/COG's already. Alternatively hire a marine engineer/architect (expensive).
Mike Johns.
Old 08-11-2004, 07:10 AM
Rep: 66 Posts: 640
And if a single steel mast is to heavy, you might want to try this set-up:
Steel Lattice Masts
Regards,
Peter
Durable Steel Hulls Wynand N Metal Boat Building 11 01-27-2009 07:19 PM
Mounting a boom higher on the mast Rehunter Sailboats 3 09-15-2005 09:02 AM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 10:35 PM
Canting mast casavecchia Sailboats 5 01-20-2005 12:15 PM
Wanted: bluewater steel sailboat plans horleywood Boat Design 4 12-28-2004 07:06 AM
