| steel hull plywood deck Looking for advice on having plywood sheathed in epoxy and covered with a genuine teak deck, on a steel framed and radius chined steel hull. Also thoughts on sail drive compared to standard prop shaft on a 43 foot steel sailboat. |
| Plywood is a great material sheathed or painted , BUT if you install a teak deck it should be glued down and NOT screwed down. The reason is eventually the deck will work a bit and water will enter the ply, causing ROT. Look at any Taiwan Tub built with glass shmered over plywood after 8-10 years. The bedding compound will have let go at many deck or deck house penitrations allowing water in to the ply. ROT follows almost instantly . A "better" system would be to lay up a foam composite sheet and use that instead of plywood. Easy to do , and lighter,with simple curves when the outer surface is glassed in place (to get proper deck curvature) and penitrations will not harm the core (not balsa). Corecell and Airex would be fine , sound & heat insulating for free. Saildrives have many many more complexity to fail than a simple 2 blade on a std shaft hidden by the deadwood, on a sailboat. For motor boats the ease of repair after a severe grounding is the plus , as is low inital cost , and almost zero design risks. FAST FRED |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| 255' Three-Masted Steel Barkentine for sale | Yachting | Marketplace | 0 | 02-09-2005 10:35 PM |
| Steel and plywood hull? | pdvjak | Boatbuilding | 1 | 02-02-2003 12:12 AM |
