#31
#32
#33
| Steel & fiberglass Quote:
http://boatdesign.net/forums/showthread.php?t=12322& It is made clear in this thread that the proper way to use steel frame parts in a fiberglass structure is to galvanize them before laminating them in, to prevent untreatable rust. From Milan in this thread: Quote:
From SamSam quoting a thread from another forum: Quote:
Galvanized steel floor parts supporting the keel and engine foundation in a fiberglass boats are very common in sailboat design. Complete steel frames are not. |
#34
Everything erodes, even SS if it doesn't get oxygen. ACQ treated ply would solve rot issues. A bigger question is the fasteners & joints. I've seen water wheels with steel angle frames & wood paddles. After a couple years the holes around the fasteners wear out & the boards rattle. Would the joints spread or compress as the 2 dissimilar materials each moved at their own molecular rate?![]()
#35
| ACQ Ply is awesome stuff for building houses with but ted655 is correct to question the fasteners as this treated wood dissolves brass, bronse and aluminum and non stainless steels. Glass and resin won't stick to it either. I would just paint the plywood and metal with paints made for each before assembly and keep the boat dry when not in use. I built two little hydroplanes out of exterior plywood (see my gallery pictures) and just dry them off after use and put them in my shop. Good luck with the project and post any results. |
#36
| gents, i just post a thread on the forum woodenboat construction, regarding "composite wood aluminium", i look for people who already experience aluminium for structural frame instead of steel ? bolting or glue with elastomere ? and so |
#37
| did some one have already experience using aluminium frame instead of steel for those "composite wooden boat" ?? |
#38
| Actually the new stuff hasn't been out there long enough to know what sticks to it. All the various companies I've contacted say they have no rekiable data one way or another. They think sanding or wire roughing the surface is all that's needed for a bond. None of them want to stick their neck out first on this though.The doubt stems from the wax used in the mix. ACQ is corossive to most metals though. It eats aluminium like candy. SS & hot dipped galvinized being the 2 that will work. I now see claimes that a new elctro plated process is suitable. I have been using Titebond 2 to glue it and have no problems. I have destroyed a few joints to test & they all have failed in the material & not the joint. I still wouldn't build a big boat out of it but a small skiff would be worth the effort. Sorry, didn't mean to steal the thread.Quote:
#39
#40
| Ahhh, sandpiper, do you want a "fair" shape or not? The difficulty in forming a steel shape (such as square tube or Z-bar or I-beam) to lie along a "fair" hull surface should not be underestimated. It is very difficult to get an exact bend and twist into the shape at the same time. If the hull and framing is limited to multiple chines with single curvature (necessary for both ease of forming and use of large ply panels) then it is most likely better to go with either stich-and-glue plywood or orgami steel, both of which would be lighter, easier and cheaper than composite framing. Which pulls us around to the reason that it was abandoned in the first place. |
#41
| Hello jehardiman, I am coming to this conclusion also. However I needed constructive debate to put my mind at rest ' if you know what I mean'. The idea was that the inner lip of the framework ' added later' would take up the twist, & allow for fair shape. Maybe as you say stitch & glue is the proven quick & cheap route to take ?. |
#42
| I am new and don't have much experience in building boats... but I work as an Architectural Technologist and have some knowledge about characteristics of building materials. And I know in buildings that we try to stay clear of mixing materials with such different properties (with some exceptions), Steel with expand and contract but to hear way more then the wood will... and wood will expand more due to moisture. So it is possible that it could cause cracking or other damage. Although it might be possible with Marine plywood... I don't know its properties.
__________________ Jason Roesler Canadian living in Chile |
#43
| Many new coatings are avaialable. http://news.thomasnet.com/news/paints_coatings/140
| Sawn frames. | Phosphor | Wooden Boat Building and Restoration | 26 | 06-01-2010 06:26 PM |
| Grown frames | Cornish Mark | Wooden Boat Building and Restoration | 5 | 01-05-2006 01:22 PM |
| Australian source for teak & holly ply | Willallison | Materials | 0 | 10-23-2004 05:29 PM |
| new free design & building project: YAGO 31' steel origami yawl | yago | Boat Design | 1 | 08-21-2004 12:42 AM |
| absolute beginner ply/epoxy or ply/glass | wannabe | Materials | 9 | 08-13-2004 05:01 AM |
