Old 08-30-2007, 01:09 PM
Bernhard Bernhard is offline
Steam Launch
Hi Folks
I have started looking at building / having built a steam launch, mostly for use on the Swedish Lakes.
I have fallen in love with the concept of the 50' Edwardian Launch http://www.selway-fisher.com/Steamover30.htm and am looking at an Engine for her. In order to propel her at hull speed (8.5 kts) about 50 bhp engine power seem to be needed.
I have found this engine here:
http://www.pioneer.net/~carlich/RSE/RSEengines.html - V - 4 Single Acting Compound but I am a bit surprised at the rather high operating pressure. Especially with this pressure I am wondering whether a triple expansion engine might not be better and a double acting to boot. Question is: where could I find one? Also their boilers are a bit confusing, what kind of boiler would you recommend?
And lastly I have been thinking of running the whole boat on LPG - propulsion, cooking, refrigeration, lighting. What do you think?
thanks
Bernhard
Old 08-30-2007, 06:48 PM
balsaboatmodels's Avatar
balsaboatmodels balsaboatmodels is offline
Rep: 17 Posts: 41
Location: Boonville, MO, pop.8700; & 415 buildings on National Register
Hey there;
Can't answer the first two questions, but can quote this as more or less relevant to pressures:
PROPANE TERMS FOR CYLINDERS AND TANKS*
Tank Pressure Unregulated vapor pressure in any size propane tank can range from about 60 to 120 psi on average. This pressure is not consistent and fluctuates constantly based on the temperature of the propane and the draw of vapor from the upper vapor space. When the temperature of the liquid drops due to the boiling process, the pressure decreases. When the liquid warms the pressure increases. Due to this constant fluctuation and the fact that the engine fuel components operate best at steady input pressures, a regulator must be installed to keep the OUTLET pressure consistently the same or REGULATED. There are two types of regulators in the propane industry as described next.
And, from another interest, you know steam locomotives?
In the main, they ran, and some still run preserved, around 150 to 250 psi.
There's those notes for whatever they're worth.
Hey, here's a fun steam-powered boat site:
http://www.steamengine.com.au/steam/...ola/index.html
Just as a novice imagining why, it would seem you'd want enough pressure to keep the cylinder moving against the torque of the prop as steam expanded inside the cylinder and its pressure declined.
later,
FSW, on the banks of the Missouri River
Favorite song: "Redneck Yacht Club"
Written By Steve Williams & Thom Shepherd
Old 08-31-2007, 06:43 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Google;
http://www.steamlaunch.com/
http://www.prestonservices.co.uk/marine.htm
http://www.theengineersemporium.co.u...sizesteam.html
http://www.steamboat.org.uk/smallads.htm
Pericles
Old 09-06-2007, 12:33 AM
artemis artemis is offline
Steamboater
Rep: 267 Posts: 411
Originally Posted by Bernhard View Post
Hi Folks
I would ask the designer at Selway-Fisher. He's very knowledgeable in the correct HP engine for each of his designs. The Reliable engine is a high (relatively speaking) rpm engine. To get the best advantages of steam you should use low rpms - the larger the hull, the lower rpms. Again, ask the designer what he recommends for a propeller, and therefore the rpm.
Having said the above there is, to the best of my knowledge, no manufacturer of traditional marine steam engines in the 25 to 75 HP ranges. A complete used engine is what you're going to need and Preston's is the only place I know of that regularly has an inventory.
Depending on the engine as to the boiler pressure - if it's a compound then 125 to 175 psi. If a triple then 150 to 225 psi. Then the boiler is deduced from that. Certainly some kind of water tube. You will probably need a code boiler in Sweden, so that necessitates other things.
You couldn't carry enough propane on/in a 50' boat to operate it for more than an hour or two. A 50 HP engine will require about 3,000,000 BTUs per hour at normal cruising speed. As I recall there's about 19,000 BTUs in a pound of propane. Oil or biodiesel is your best bet.
You might contact the Swedish Steamboat Association at http://www.steamboatassociation.se/ for further info. They can probably help you.
Old 09-06-2007, 04:52 PM
Steamboater
Rep: 267 Posts: 411
I now get to eat my words. Totally forgot above a used US Navy "M" 50 HP engine. Being handled by Elliott Bay Steam Launch - http://www.steamlaunch.com/engines/AntiqueEngines.html - it will suit your needs very well; a sturdy, US Navy grade engine, excellent materials and craftsmanship. And I happen to personally know the people that Elliott Bay recommends to do the restoration work. They're GREAT!
Hope this helps.
Old 09-21-2007, 12:57 PM
fredrosse fredrosse is offline
USACE Steam
Rep: 25 Posts: 46
Rough Calculations show only about 10 - 15 horsepower required for hull speed of 6.5 knots. Turning a prop about 24 in dia x 24 in pitch, 450 - 500 rpm. (a somewhat larger prop at lower rpm would be somewhat better).
For a reasonably efficient compound engine, only about 350,000 BTU/hr (100 kWthermal) boiler output will do OK. That would require about 5-6 US Gallons per hour of propane, somewhat less with oil firing. You would probably be better off with oil firing, and just carry the propane for the other services (cooking, etc.)
Excessive steam Marshall1 Sterndrives 3 06-23-2007 09:55 PM
steam launches greg simpson Open Discussion: All Things Boats & Boating 39 07-06-2006 12:43 AM
Steam jet boats A_Appleyard Boat Design 16 11-02-2005 09:19 AM
steam engine yipster Powerboats 30 04-19-2005 11:55 AM
Steam Engine emanresu Boat Design 3 01-20-2005 09:51 PM
