Originally Posted by greg simpson ... have you thought about how high steam consumption would be if a boiler exhausted straight into water?... |
The power is in the steam that comes out of the boiler. Running it through cylinders and gearing and shafts and a propeller does not make it into any more power :: efficiency cannot be more then 100%. with a steam jet, the pipe from the boiler to the blast nozzle would have to be kept as short as practicable to avoid friction losses.
If the steam blast is turned into an air blast by a PDX-type device, what would be the % efficiency of that power conversion?
Then if the resulting air blast came out of an underwater stern vent, the blast it would push against the water as well as having a jetplane-type effect.
