Old 11-02-2006, 09:06 PM
Randerso Randerso is offline
Rep: 10 Posts: 7
Standards for measuring waterline length
I am drafting rules for our neighborhood marina. We want a rule that limits the lenght of a vessel in a slip to avoid overloading the floating dock structure. We have decided to use the waterline length as the measure.
It seems simple enough to measure the waterline length if necessary with a tape, but I suspect this is easier said than done accurately - especially if there is an issue of a boat being too long to qualify.
Is there a standard for determining actual waterline length, or specified method of measurement? If so, we would like to reference it in our rule.
Old 11-03-2006, 04:26 AM
Poida Poida is offline
Rep: 395 Posts: 1,072
At some of our ramps we have a maximum length of boat you are allowed to launch. This seems practical as you can measure the boat prior to launching. The water line length, unless I don't understand the term, means the length of the boat measured at the watereline that you won't know until the boat is in the water. Then it will be too late. Most boats have a standard curvature at the bow so add the bit that is generally above the waterline and restrict the overall length.
Old 11-03-2006, 05:26 AM
Crag Cay Crag Cay is offline
Rep: 547 Posts: 629
I think you will be making a rod for your own back if you decide to use LWL. Your customers want something that is seen to be fair and equitable and you need something that is easy to check and enforce. Unfortunately, I think LWL would be neither of these.
Either go with LOA but be clear about what is and is not included (bow sprits, anchor platforms, davits, solar panel arays, anchor rollers, swim platforms, etc, etc...)
Or use some form of Hull Length (LOD), but then you still need to have a some way of dealing with boats with massive bowsprits, etc.
If your only concern is 'overloading' the docks, then displacement (total weight) would be more appropriate, but in my experience, the problem is getting people to use a big enough slip to completely contain their boat without having bits hanging over and blocking either the walkways or access channels. LWL would not solve these problems. A boat that was 25 ft LWL but that was 38ft from tip of bowsprit to tail of bumkin, would be a real nuisance in a 25ft slip.
Old 11-03-2006, 10:21 AM
Rep: 10 Posts: 7
Thanks - These comments are very helpful.
This is a private marina (all 40, 50 and 60 ft wet slips) that has been in service for a few years with no enforcement of boat size. As usual the developer will sell anything to anyone. Now that the owners are in control and concerned about consequenses, if we use LOA a good number of exisitng boats will be non-compliant. We are trying to balance an out-of-the-box unenforceable situation with preventing some owners from damaging the docks.
Any additional thoughts are welcome.
Old 11-03-2006, 01:06 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Then use LOA multiplied by some correction factor to make the rule fit the biggest of the already too large boats.
Yoke.
Old 11-03-2006, 05:45 PM
Palmer Palmer is offline
Rep: 10 Posts: 53
You could also make the new rules for new tenants and grandfather in the existing vessels that don't comply.
Old 11-03-2006, 11:09 PM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
Yoke.
EXCELLENT Idea!
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 11-05-2006, 11:58 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
======"Either go with LOA but be clear about what is and is not included (bow sprits, anchor platforms, davits, solar panel arays, anchor rollers, swim platforms, etc, etc...)"===
Measure only bouyancy section of boat.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
measuring outboard prop hp? kenfyoozed Boat Design 4 03-18-2005 06:00 PM
ABS Standards Cheetie Boat Design 3 11-16-2004 05:37 PM
Hull Waterline Length to Beam longngone Boat Design 12 10-22-2004 12:37 PM
Measuring odd shapes, duluthboats Press Releases 2 08-11-2004 04:45 PM
Measuring a hull duluthboats Open Discussion: All Things Boats & Boating 6 11-07-2002 02:42 AM
