Have I understood you both correctly, should hardagoo and I, make a ss 316L rudder and have it powdercoated with a nice white paint, if the boat is also a nice white colour, I will have problems at a later stage, because I seal the surface of the SS316L and the chromium can't breath. Good that I read this thread, I would have blindly gone through the expenses and had it powdercoated. Thank you so much for the information provided. Bert |
| Stainless coating Hello all, I found the link on Youtube please see http://www.youtube.com/watch?v=j1SZT2xcuuY I think you will get a better idea than I can describe in written form. Please note the coating had not been polished in any way, was simply coated and placed in the water where it remained for slightly over ten months. had the coating been polished to say a satin finish the result would have been the same (no corrosion). Hope the above link helps. |
| why is that people do not read before opening their mouths Dear Ms/Mr. leave it. If you took the time to read the thread the question was posed to me directly about the potential of reducing the weight of existing Stainless steel rudders, each weighing 60 LBS. My reference was to perhaps replace the SS rudders with a lighter weight substrate and if still wanting to have the appearance of SS then it could be coated with what has been proven to work for many years, with zero crevice corrosion. It is used on Ocean going tankers for at least ten years. So, I suggest before climbing all over someone who was asked for advice and gave it humbly, you take the time to read. I will not post again as this type of BS is not worth my time. Enjoy! |
| Nice! ...at least you have choosen the right board name ![]() And you have NOT being asked to post that nonsense as a reply on the original question: Quote:
leave it! |
| Stainless Thanks lewisboats for clarification. My intent was to indicate an alternate potential for keeping the look and properties of stainless steel while drastically reducing weight. I am attaching (hope it works) images of a rudder from a two racing yachts which were coated with SS 316L and then polished. The original rudders were fiberglass and was prepped just the same as one would prep for paint. The SS was sprayed on using an automotive spray gun and added approx. 50 grams per sq foot of weight when complete. The owners of the vessels have stated they are enjoying great success with maneuvering in light winds. |
| Free of charge, Steel - polyurethane foam -Steel insulation sheets | rossgiles | Fiberglass and Composite Boat Building | 0 | 03-18-2008 06:43 AM |
| Outboard rudder vs. inboard rudder | designdreamin | Boat Design | 0 | 06-27-2006 10:05 PM |
| Rudder Angle And Effective Size Of Rudder... | saildog | Sailboats | 5 | 03-06-2006 03:34 PM |
| New Rudder VS Old | Cliff Ruckstuhl | Sailboats | 4 | 04-23-2005 11:28 PM |
| New Rudder verses Old Rudder | Cliff Ruckstuhl | Sailboats | 0 | 03-06-2004 03:36 PM |
