Old 10-14-2003, 12:35 AM
Stability Crieria
I would like to know the FRP boat Stability Criteria.
Old 10-14-2003, 02:19 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
There is none ...
Your question has to be a lot more specific to get any kind of useful answer.
Sail or power? Race or cruising? Dinghy or rowboat? Fishingboat or barge?
Size? Intended area of use. Location, EU have different governing bodies than the US and so has most other areas.
Since every governing body that deals with this looks at each other, some of the regulations are not that different between areas, but I have no idea if this is the case for stability.
And most importantly what do YOU mean by stability criteria?
Do you just want to get a reasonable number for AWS for your boat?
So specify to get an answer.
ErikG
Old 10-14-2003, 05:05 AM
Sorry, I would like to know the Stability Criteria of 30ft Fibre Glass median speed ferry boat for river crusing. I have only experience in stability calculation of the Steel boats. I use GHS Hydrostatic Calculation Program. I need to set the stability criteria in the program but I am not sure whether fibre glass boat and Steel boat are same criteria or not
Thank you for your kind and quick reponse.
Best regards
Kyaw
Old 10-14-2003, 05:32 AM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
Most individual governments' regulations mirror those promulgated by the IMO in the Code on Intact Stability 1995 (with ammendments in 2002). The 1995 version may be built into your software. Ships must conform with all five principal criteria using the offshore (or unprotected waters) factor. There may be differences in standards for small passenger vessels depending on the country. In the US you need to establish which category applies to you (I'm thinking it would be "T") and then look it up in the Code of Federal Regulations #46, or "46 CFR". Your region's US Coast Guard Marine Safety Office can help you.
What material the hull is made of is probably irrelevant.
Old 10-14-2003, 07:35 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Having worked as a commercial naval architect as well as a pleasure-craft <shudder - I hate that word> designer in England and the US, I have to admit that the stability criteria have never differentiated between boats built of different materials.
From dinghies to super-tankers to heavy-lift crane barges, stability is stability....
New (possibly) idea for monohull stability in rough seas sryth Sailboats 45 08-24-2005 06:41 PM
Directional Stability Wardi Sailboats 9 06-01-2005 02:10 AM
Understanding Stability and Trimming Calculations Brian Boat Design 0 07-27-2004 02:38 AM
Full Displacement of semi tdamico Boat Design 51 02-18-2004 10:42 AM
Sailboat stability... ErikG Boat Design 7 11-30-2003 12:53 PM
