Old 04-13-2004, 02:17 PM
BillyB BillyB is offline
(SQRT.)LWL x 1.34
If theoretical Hull speed for a displacement vessel is determined by the sq. root of the length of the water line times 1.34, then what is a displacement vessel called which can exceed it's Max. Hull speed.
BillyB
Old 04-13-2004, 04:49 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
The most common term is semi-displacement, but I think semi-planning is more accurate for a boat that is almost planning. You choose and there will always be someone around to disagree.
Gary
"The hand feeds the mind."
Weston Farmer
Old 04-14-2004, 02:29 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
Either what duluth says, or you could call it "skinny", since a slender vessel will exceed it's "hull speed" quite nicely, thank you.
Be vewwy vewwy careful about using the expression "hull speed" in these parts, as there are pirates everywhere who may pounce.....
Steve
