Old 08-21-2010, 10:03 PM
wardd wardd is offline
Rep: 443 Posts: 925
Originally Posted by ancient kayaker View Post
Possibly, but if there is no gap between the sections it should be possible to have them rigidly attached together, since there is no elastomeric seal between them. If flexing can be eliminated the tape may be OK. You could use duct tape but it would look icky and the stuff I get won't let go!
No paddler with a wood kayak or canoe should leave home without it! Discovery TV channel have done some interesting things with duct tape, including building a working, 2-man sailboat and lifting a car.
I was unable to get hold of my favorite double-sided outdoor carpet tape so I used duct tape to make my last sail from a tarp. I rolled it with the adhesive outside (dah) and used the tube like double-sided tape: it worked!
no flex would be ideal but I would allow for it anyway and design to compensate
when I design something I ask what will go wrong then assume it will and make allowances for it
Split mast AdrienJousset Boat Design 6 07-13-2010 11:27 PM
Split Mainsail. Has this been tried before? Omeron Sailboats 21 11-18-2007 10:27 AM
split down the keel MDP Fiberglass and Composite Boat Building 9 09-15-2006 05:05 PM
split keel Gaia_jan Boat Design 15 02-10-2005 08:29 PM
Split the boat Ken Open Discussion: All Things Boats & Boating 6 03-08-2004 07:23 PM
