| Is this a sound boatbuilding method? Is using this type of foam a sound building method? http://www.magallanesboatbuilding.co...e%20method.htm |
| Had trouble acessing the site..... Although, the word "foam" causes me to take a deep breath - and pause. Last edited by tri - star : 03-16-2007 at 08:32 AM. Reason: SSpelliing |
Ateve....I mean Steve PS: Me too on the site link...error message 404 |
| I think that boat is sound as long as it's on a sheltered lake! |
| http://www.magallanesboatbuilding.co...e%20method.htm http://www.magallanesboatbuilding.com You get a lot of floatation, but if you hit something you have a very thin outer skin (or the boat will be much heavier than needed) and a very low density (weak) core. |
The ##%%^$$@**@ link captured my browser! Making me reload the forum. BUT... my answer is... If it floats and performs after it's built, then it was successful.That being said, you couldn't give me a foam core boat! Water eventually finds its way into the core. Even though it doesn't sink, it becomes a water ladden sponge with no real fix. Give me a boat with a material that keeps the water on one side & displacement on the other. THEN, it can be fixed from both sides. Take a sponge, put it in a baggy and support a load on it. Now make a teeny-tiny hole in that baggy and watch the load. NOW, remove the sponge/baggy & try to dry that sponge again while still in the baggy. Just my opinion of "cored" boats
| I agree :-) |
| Agreed ! I agree with the last 4 posts ! - Several posts re: low density cores, have been made by us. - Will not repeat myself here. Except that the hull is maybe 20% of a vessel. In cost - and otherwise. So why, scimp here - and jepordize the whole venture ?! Cheers ! |
| Well sandwich construction is not something new. Currently Cup of America boats are building using this method: http://alinghi.epfl.ch/page10240-en.html In my opinion it depend what kind of boat we are talking about. For cruising boat the argument of Raggi_Thor about the thin skin, which hit something, is valuable. However it is not expected that a Cup of America boat hit something and if so will be immediately repair by competent experts. It is not cheap however .All the best, CapKos |
| I would say that I find much merit in a sandwich design. It is possible to build very strong and light hulls that way. America's cup participants have a slightly larger budget tha most of us amateurs and can afford to use epoxy, kevlar, carbon fiber on aluminium honeycomb structures as core. (See e.g. http://www.victorychallenge.com) A sandwich bottom also insulates from the cold water, an important aspect if you want to use the boat out of season in northern waters. As for the building method with fibre glass, polyester and uretan foam as core, I mostly object to the polyester resin. Polyester will let moisture through. I wouldn't trust injected uretan foam as core without test data showing that it can withstand the forces the design brings. If polyester is exchanged for epoxy and each volume being filled with uretan foam isn't too large, I don't see why the method wouldn't work well. As far as I know, uretan foam won't absorb water in case the epoxy/glasfiber surface is breached. For a leasure boat, as a contrast to a racing boat, I think it makes sense to design the bottom surface for more abuse. If the intended payload of the boat is e.g. 1 ton, it doesn't really make sense to design a superlight hull (200 kg?) even though it is possible with the sandwich techniques available with large budgets. I would add a few hundred kg in the bottom, also improving stability. A boat isn't only the bottom, and for the rest of it I don't see why the proposed sandwich technique with polyester/glasfiber/uretan foam wouldn't work, though I still prefer epoxy Opinions from an amateur open to new ideas, Erik |
| Easy to agree with you; CapKos: However, using Gold Cuppers, as examples of anything useful: can get you onto sticky ground. As, even if they cost a jillion Eros/Dollars.... They are throw - away - boats. Their value diminishing rapidly after their last race......... The question asked was: " Is this a sound boat building building method ?" - If it's a special purpose vessel - with a limited life expectancy, speaking for myself - I might be persuaded, to design such a creature. - However; if the owner wants a craft, that they wish to cruise on - with minimum time spent in boat yards......I will not design them a yacht with a low density, cored hull. Irrespective, of how deep their pockets are. After a few years, cruisers, will often exceed the designer's worst expectations re: actual weight in the water. Well exceeding, any theoretical savings in displ. gained by light weight sandwhich construction. Within the hull structure, proper. Within the vessel it's self - I have less reservations. But even there, honeycomb - and a mutitude of other mat. Will be well ahead of foam - in my personal vessel. i.e. Having been also, in the business of designing/building houses, I have noticed some areas - of concern - that no one seems to want to talk about: Re: Foam(s). Like time, temp. and catalysts. In the lab - a few days old - you will always get impressive numbers, for various foams. Re: Insulation R values. Or impressive gains, acheived in strength in cored situations. Now everything fades with time. This is expected. However, when I looked at real world situations. Time and Heat can be of more concern, with foams. - Than with many; better understood, traditional materials. Consider: Most foams are created by a catalytic process. The catalyst never stops working. So the properties of the foam are not static. So 3 yr. old foam will not show the orig. specs. Heat adds to this concern. A cored vessel in the tropics will see faster changes than one moored in Rhode Island. Why don't we do a survey ? I will predict - right now - foam will not be the first choice of experienced custom boat builders. Production boat yards are another story. Cheers ! |
| New Ultralight Boatbuilding Method | Antonio Bordeu | Materials | 17 | 03-15-2008 08:16 AM |
| Want more sound | DarrenPayne | DIY Marinizing | 39 | 06-05-2006 11:44 AM |
| Puget Sound look out! | duluthboats | Open Discussion: All Things Boats & Boating | 9 | 11-11-2005 04:06 AM |
| thinsulate sound insulation | nilo | Open Discussion: All Things Boats & Boating | 12 | 02-15-2005 03:31 PM |
| sound reduction coating | AAllen | Marketplace | 0 | 10-16-2003 08:03 PM |
