Old 04-10-2008, 11:22 PM
fcc fcc is offline
Solarpower boat
I am entering a solar boat competition, and i am required to use only the following materials:
-4 x 12% efficiency solar panels,
-block of foam (for hull)
-radio control
-an electric engine with switches
-a propeller shaft and propeller,
-acrylic plastic
http://www.solarchallenge.com.au/
any advice concerning the design or production of this boat would be appreciated.
Old 04-11-2008, 12:41 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
-radio control
-acrylic plastic
I had a play with solar boar designs back in 1997, however they are probably bigger than what you are looking at. See:
http://www.cyberiad.net/library/mult...lar1/solar.htm
Factoid: The winner of the inaugural solar boat race in Canberra was a cat funded and piloted by Bob Clifford of Incat fame. I think he spent well over $100K on the boat.
Good luck!
Leo.
Old 04-11-2008, 02:26 AM
Previous Member
Rep: 0 Posts: 0
Make an initial estimate of the weight and power output from the solar cells. Most important thing is weight and power output of the cells.
A long slender hull will work best. It can be stabilised with outriggers.
If you do the above estimates I will take you through the design process that should get close to the optimum result.
Making the ideal prop will take a little skill but not too difficult.
Rick W.
