Old 08-25-2005, 07:34 AM
masrapido masrapido is offline
Junior forever
Rep: 281 Posts: 258
Rob them senseless waveless.
I liked the insufflation a lot. Radiating into the vacuum!
Who found condensation block attached to an air pump high-tech?
Rob them senseless vaweless.
Old 08-25-2005, 04:32 PM
waveless waveless is offline
Registered
Rep: 10 Posts: 92
Mr. Jonathan,
Your advice is good for the project, now I am redesigning the condenser and the evaporator. The condenser, I will use aluminium heating radiator, and put together with the lens heating part, it is light and saving space. the evaporator is also very import for high quality fresh water, I will design a small tower for that by mature technology.
For Solar Desalinator project, I am try to make a standard solar system for the boat, I am designing the new solar system in detail, I will calculate how much fresh water can produced per hour, how much it cost is, also I make it to generate electricity. These are very important for a boat. I know this project must work, there are only the more or less efficiency problems. I think my system will more efficiency then present solar electric system, their system only can use 12% solar energy and very expensive. If my system can reach 50%, it will be the great success. Because present solar electric system can only generate electricity, my solar system can generate efficiency and warm fresh water. I know that solar electric system have a long way to go to improve the efficiency, because their material only can absorb part of solar ray in spectrum. I can sure that the efficiency of my solar system will reach 50%, because the efficiency of the vacuum solar collecting glass tube is about 90%, and the efficiency (for whole day) of present heating system is 55%. It is possible that my solar system can reach 70-80% of efficiency, this is much more efficiency than solar electric system.
Jonathan, I am not a business men, I am a engineer, I only know how to make the project, this is why I need your help. I know a lot of people interest on this project, I hope you can do some organize work for this project; lets more people join us to make it out and get profit, and pay the risk. I am no mater how much I can earn; I only want to make it come true.
I would like do two project at same time, because I have another good project can earn easy money that I will tell you late. Do two project at same time can save a lot of money, because we only need a office, a work place and a car. Also if one project not earns money then another project may earn money. If we start the projects in china, it will be cheap.
Best regards
Yanchuan Wu
Old 08-26-2005, 04:26 PM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
I suggest another course. Do good work. Make the world a better place. Every little bit helps!
http://www.swc2005.org/info.htm
Old 08-27-2005, 04:43 AM
Registered
Rep: 10 Posts: 92
Hi,
I find a problem, if the boats change the direction at all time, then It is very difficult to adjust the focus of sunlight.
Could you give me some idea?
I have calculated,
20 square meter can generate electricity:
maximal: 10000wph
minimal: 3000wph
fresh water:
200Kgph
Old 08-27-2005, 02:34 PM
imagineer
Rep: 58 Posts: 436
The difficulty of focusing sunlight on a moving vessel is real. That is why the original idea you showed of using vacuum to lower the vaporization temperature makes more sense for a boat. You can use photovoltaics to power your vacuum pump. I think it only takes a small negative pressure to accelerate the vaporization.
Old 08-27-2005, 03:28 PM
Registered
Rep: 10 Posts: 92
Ok,
A motor, a chip and 10 photoelectric diode can solve the problem. it is cheap.
Old 08-27-2005, 04:10 PM
imagineer
Rep: 58 Posts: 436
Originally Posted by waveless
Ok,
It may not be so simple as you think. The concentrator will be hunting for focus every time a wave moves the boat. Unless it moves instantaneously, you lose a lot of heat. You can't have the reflector attached to the collector or else you also have to move the weight of the water. You could use a single fresnel lens but in order to get the high heat that you want you need a big one and it has mass considerations as well as windage. Take a look at:
http://www.practicalsolar.com/products.htm
A small heliostat system with lightweight reflectors could work, but needs quite a bit of engineering.
http://www.renewableenergyaccess.com...story?id=33773
But if you could manage to engineer a reliable small sun tracker, then you can put photovoltaics in place of the mirrors and get a 50% increase in power output.
http://www.sunpowercorp.com/html/Pro...olarcells.html
Old 08-27-2005, 04:59 PM
Registered
Rep: 10 Posts: 92
JonathanCole,
It is no problem, my lens only need adjust one dimention. I have regesigned the solar collector and condenser, the remain vapor is about 30-50 degree after doing work, it is esay to be condensate.
I will show you the new design late.
Old 08-27-2005, 07:12 PM
Junior forever
Rep: 281 Posts: 258
24.08.05. from waveless:
"...I am not a exprienced mechanical design, but I have exprience for electric, computer and software."
25.08.05.
from waveless:
"...I am a engineer..."
Not that I know anything, of course, but instead of messing around with "vacuum" to reduce temperatures, how about good old shade? Or simply get rid of a lense. Or both. That will keep water cool.
By the way, there are solar heating systems in Chile, dsigned for houses but no brainers to adapt to use on boats or land. Cheap as chips, as you would imagine. Anyone?
I wish not to limit anyone's freedom to keep inventing hot water though.
What is insufflation on these images and why is radiating in vacuum?
  #25
Old 08-27-2005, 07:17 PM
Junior forever
Rep: 281 Posts: 258
Oh and this one is interesting:
"I have regesigned the solar collector and condenser, the remain vapor is about 30-50 degree after doing work, it is esay to be condensate."
Water used to turn into vapor at 60+. At 35-50 degrees it is just a warm water. No desalination on these temps with efficiencies claimed (50%). It would take more than a day to separate water from salt (for a certain amount of water. More you have, higher temperature is needed)
  #26
Old 08-27-2005, 07:20 PM
Junior forever
Rep: 281 Posts: 258
No condensation at 35-50 either. Vapor does not exist at these temps.
  #27
Old 08-27-2005, 08:00 PM
imagineer
Rep: 58 Posts: 436
Waveless is not trying to design a water heater. As you point out, that has already been done. Waveless is trying to develop a solar desalinator device that can be used on a boat.
Vacuum is for reducing vaporization temperature, not for cooling water. This means using techniques for increasing vaporization of saltwater (heat, vacuum), while also increasing condensation of de-salted water (preheating incoming cold water by cooling condenser, or evaporative cooling). He also wants to use vapor pressure to generate electricity (through some kind of turbine?)
  #28
Old 08-27-2005, 08:03 PM
imagineer
Rep: 58 Posts: 436
The temperature at which water evaporates is dependent on saturation of the atmosphere. At 25 degrees Centigrade (room temperature) it is possible to have 90% humidity (vapor saturation). Perhaps you are thinking of steam.
  #29
Old 08-28-2005, 04:04 AM
Registered
Rep: 10 Posts: 92
Yes, the vapor that temperature less than 100 degree is called steam.
you can search by google that remain steam temperature of the steam turbine is about 25-45 degree.
dtQ=C*(T1-T2)
W=dtQ-dtU
W=C*(T1-T2)-dtU
W work,
Q Heat,
C Thermal capacity,
T1 temperature before doing work,
T2 temperature after doing work,
U is the internal energy
It means the more work to be done the less temperature remain.
  #30
Old 08-28-2005, 06:26 AM
Registered
Rep: 10 Posts: 92
The temperature of 1g water increase 1 degree, it need 1 calorie heat.
200kg water increasing temperature from 50 to 120 degree need 14000kcal.
Q = 200kg * 70 = 14000kcal.
The sunlight energy of a 20 square meter in the noon is about 20000Wph.
Because, 1kcal/m2·h = 1.16279 w/m2
Q(sunlight) = 20000 / 1.16279 = 17200 kcal
If the efficiency of my solar collector is 85%, then the solar collector can absorbs 14520 kcal heats. It is possible to heat the seawater from temperature 50 to 120 degrees.
The 14520kcal energy will transmit to evaporator generate vapor, and drive turbine working. The loss of energy in transmit ion and evaporate are about 10%, the energy loss in turbine is about 20%, the loss of electric generator is about 10. The total energy that is converted to electricity is about 14520 kcal*60% = 8712 kcal.
8712 kcal is equal to 10130Wph.
The data in calculation are reasonable, you can check the data by google. Because the energy to be reused in the system, there are no leaks of energy except heat transmission, sunlight reflect and a part of internal energy loss.
Wind Generator or Solar Wynand N Sailboats 8 02-07-2005 09:12 PM
Solar Panels sunshinesolar Boat Design 0 08-27-2004 02:49 PM
Rudder design for solar boat lost at sea Boat Design 9 01-26-2004 12:39 PM
solar splash quangha1944 Boat Design 37 08-25-2003 09:53 PM
