Old 05-09-2009, 11:19 AM
Revel Revel is offline
Rep: 10 Posts: 4
Software
I am wanting to model a simple plywood hull shape with 2 flat sides and a constant radius to the chine. Any advise as to which design software will be the most appropriate for this application.
Old 05-09-2009, 11:32 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
freeship...or give me the numbers and I can sketch it out for you. I need max beam, location of max beam from aft of transom at lwl, lwl, loa, Vee or flat bottom, beam lwl fwd, beam lwl aft, angle of side flare in deg from vertical, amount of keel advance or forefoot if a Vee bottom, amount of deadrise and anything else you can give me for the hull dims. Also I need elevation of the chine forward and aft and proposed displacement in salt and fresh water.
Steve
Old 05-09-2009, 01:21 PM
Rep: 10 Posts: 4
Many thanks Steve. I will give it a try, but if i get stuck I will get back to you
Old 05-09-2009, 02:12 PM
Rep: 10 Posts: 4
Hey Steve, downloaded software, but where can i get user manual or help.
Rodney
Old 05-10-2009, 04:29 PM
lewisboats's Avatar
Obsessed Member
Here's a copy but it is available on the same site as the program. A google of Freeship gives the link to the sourceforge site
There is a Yahoo group for help Freeship HtandT
steve
Old 05-11-2009, 08:16 AM
Rep: 10 Posts: 4
Many thanks, will try it
Rodney
Software TheRefugee Software 50 11-23-2009 06:55 AM
Software weys Multihulls 2 01-12-2007 01:26 AM
What software? guest Education 0 12-01-2004 05:55 AM
best software for ...??? ivansalasj Software 0 02-18-2004 03:23 PM
The right software Archive Software 1 06-12-2001 03:50 AM
