Old 10-22-2008, 02:12 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Small working tugboat
I'm posting these images for the hull of a small working tugboat I've begun to design.
It's an 11.7 foot boat for towing heavy loads and working in shallow water. It's about 6.5 feet wide and has a box keel and a tunnel-stern like the Atkin Seabright skiffs which means a protected prop and rudder (not yet shown).
It's not designed for semi-planing speeds, this one is strictly a displacement speed hull with the specified 5-10 HP inboard diesel. It should be easy to build in plywood, there's only a little bit of twist in the bottom panels, the rest of the hull is just simple bends. I'm thinking of plywood / epoxy / fiberglass composite sandwich construction but I suppose any sheet material would work.
Comments welcome, but remember it's not finished yet ...
Small working tugboat-tug01-12.jpg  Small working tugboat-tug02-12.jpg  Small working tugboat-tug03-12.jpg
Kenneth Grome
Old 10-22-2008, 05:32 AM
aztek aztek is offline
Rep: 36 Posts: 15
lovin the boat
Old 10-22-2008, 07:36 AM
Village_Idiot Village_Idiot is offline
Rep: 75 Posts: 238
Maybe consider enclosing the prop totally inside a tube or at least a shroud. This should increase thrust, especially if you can keep the prop tips close to the wall of the tube/shroud, say within 0.5% of the prop blade length. Sort of like a tractor jet, but with better efficiency.
I still like the idea of a transverse tube in the bow (below waterline) with a TMD (tip magnetic driven) prop that could be used as a bow thruster - but it's probably overkill for this project...
Old 10-22-2008, 11:22 AM
robmill54 robmill54 is offline
Rep: 18 Posts: 17
I like it, it looks a lot like the 14ft Candu E_Z tug. I have the plans for it and it's close.
What program are you using to design this?
Old 10-22-2008, 12:49 PM
Rep: 287 Posts: 719
I used FreeShip 2.6. The original file was sent to me from someone else, but I remember that the boat started as a 9 footer before I enlarged it just enough to make it useful -- and totally changed the bottom. If there's a 9 foot version of the Candu E_Z maybe that's where the original file was drawn from?
The person shown is sitting and if he wants to stand in the house it's going to have to be taller, I can see that.
Kenneth Grome
Old 10-22-2008, 03:38 PM
Rep: 18 Posts: 17
Thanks, there is a 11ft model here is the link;
http://www.berkeley-engineering.com/CanduJr.html
Old 10-24-2008, 04:14 AM
Rep: 287 Posts: 719
Cute design, and almost the same as mine from outward appearance. The bottom is probably much different though because mine has a classic tunnel-stern Seabright bottom and the CanduJr has really huge planing fins which mine does not, but they do look a lot alike from the side.
Kenneth Grome
Old 10-26-2008, 11:28 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
I doubt this arrangement or hull form makes much sense for a truly useful working boat. Tugs are shaped and arranged the way they are for very good reasons.
The cabin and freeboard forward on this design makes it impossible to get on or off (or work over the bow) easily around a large portion of the boat. A low rail and easy access all around are required, otherwise you have to turn the boat completely around to get off....a waste of time.
Controllability is another key factor in the usefulness of a small tug. This boat has far too much windage and not enough under water. While the shallow draft may be useful on occasion, having the boat blow all over hell and having to constantly goose the throttle to get her to turn will be a constant pain. These tunnel stern boats are notoriously lousy trying to maneuver at zero speed.
We have a couple of very useful ting tugs here in Silva Bay, with relative mouse-power they do a great deal of work. The larger boat is Seka (13'6" LOA), with 6 HP BMW diesel turning a 11" by 8" prop, the smaller boat is Sophie (10'4" LOA), 13HP Beta turning a 12" by 12" wheel. Both boats draw 12-15" of water.
Old 04-21-2010, 11:46 PM
yosipanji yosipanji is offline
Rep: 10 Posts: 4
After I read this Interesting article from this link http://www.ratson.com, i got an idea to make 3d models and miniaturs of Tug Boat for business & military purpose..
does anyone have other references?
brgds,
yp
21' small tugboat plans jackason Boat Design 8 07-22-2008 02:53 AM
Harbour tugboat horesko Boat Design 1 09-09-2006 08:34 AM
Tugboat info needed JonCynthia Boat Design 2 07-18-2006 02:58 PM
New Tugboat Gallery LHKeeper Open Discussion: All Things Boats & Boating 0 06-01-2005 05:02 PM
tugboat design.........anybody knows somethings stavrou2000 Boat Design 1 10-06-2004 06:27 AM
