| small stell boat Hi, I have a number of pieces of steel salvaged from a houseboat remodelling job I did. I've not built a boat before though have renovated a few. My plan is to build a 13 foot flat bottom boat, 5 foot beam with a plumb bow. I have nearly all the steel, 6mm (1/4) for the bottom and 3mm (1/8) for the sides, The boat is to be used (and left) in the river (Thames) where I live. It's non-tidal and very flat. I calculate that with an inboard diesel the boat will draw 200mm (8") leaving a freeboard of 550mm (22"). It'll weigh best part of a tonne, but that doesn't matter if she stays in the water. Can anyone throw any light on my plan, your welcome to scupper them! |
| i think you can do a box with your metal sheets but not a "boat". 3m96 LOA is too small. It will sink. Adding an inboard diesel into it is just a larger dream..sorry. lucas. |
If it displaces the water relative to weight it leaves a reasonable freeboard, why would it sink? Are you aware of any deficiency in my welding perchance? |
| Something like this? |
| following thoughts about ur boat hello again. I did a small drawing and i computed then..I think such boat will at least displace 500kg (perhaps 450 kg) of water. Then only the plating of sides and bottom will reach 320 kg. it means taht you have 180kg left for you (the weight of the captain) , a little bit of strucure, ,deck ,gunwales, and your engine and your d.o tank. So it is a little bit short. 6mm is too heavy... i think. |
The boat will have a plan area of 4m2 - at 250mm thats a tonne of displacement, given that overall I have 750mm sides I'd need 3 tonne to break the freeboard - OR am I missing something? |
| i did not understand that you intended to do a box. Yes your calculation are good (exept with a box 1500 mm or 5 feet for breadth) i find 1500 kg of water displaced ( 4000 *250 *1500) or (lwl*draft*breadth). What i tried to do before was something that looks like more a usual hull shape. i did a preliminary sketch of what could have been line and i arrived at the calculations mentionned in the preceeding message. But with this idea of doing less simple form , true you would have had a more complex sheet shaping and forming process and maybe very hard to do). I hope you understand what i say ( my english). So good luck for your "boat" . bye |
| mechanical properties of stell | ilgazcan | Materials | 6 | 11-08-2008 10:48 PM |
| Your Boat is too Small | brian eiland | Boat Design | 2 | 09-20-2007 08:28 AM |
| Small boat design | BWD | Boat Design | 6 | 09-14-2007 08:13 AM |
| Boat Size, How to tell that your boat is to small | brian eiland | Open Discussion: All Things Boats & Boating | 10 | 06-07-2007 05:21 AM |
| small boat | ajaykumarjha | Boat Design | 0 | 01-01-2005 05:08 AM |
