| small performance sailing dingy plans I want to build a boat. Can't get the idea out of my head. My mind has wandered from a 25 ft trailerable to a little minicup once published in popular mechanics. All came up leaving me wanting. Here is what I want to do. I want a boat that will fit in the back of a pickup truck. Lets say under 10 feet no wider than 5 feet. Needs to be light. It needs to be able to be sailed to it's capabilities by one with room for two. I am a performance freak. I would like it to have no aft stay or runners just swept shrowds so I can run a big full roach main, a non-overlapping jib, retrachtable sprit for asymetrical spinniker. Some ideas I have had are a tunnel for spinniker like a 505 has, and an open transom. Boats I like, the viper, international 14, 49er, and melges 24, all have the look and ideas i'm after. Another idea would be to add a lifting keel with nice high aspect ratio and a bulb and then stick it on a trailer This will be a do it yourself project. Building materials could be anything, wood, fiberglass, even thought once about carbon fiber (cost may kill this idea). I am not opposed to learning to make a mold. Or use alternate methods of lay-up such as strechting mesh over stringers and laying it up from the inside out. This project will be more about the building than the end result. I know how to sail I want to know how to build a boat. Thats the idea. Is there a question in all of this, yes. Is there a design already out there that would satisfy my all or most of my needs? and if not what would it take to commision a design like this? If I get nothing more than a set of paper dreams then that would be ok as long as they are my dreams. this would not be an AC Team budget, but rather a few buddies and a six pack of beer budget. Any help anyone? Just think we could put our name in Sail magazine "... the 2012 boat of the year, a ****** and Sinsley design" Dreams!! Devon |
| of course there are many designs already out there, and you are as qualified to read about their attributes as anyone. Your favorire modifications to that existing design would definately be a good subject for discussion here. Many good designs could stand far greater sail areas (and earlier/faster planing) if modified with a canting keel on a deep foil. Since a dinghy hull is generally meant to be sailed upright, the hull should change little with a canting bulb keel (a straight ballasted keel/ballast would not be effective until heeled, so the hull itself would in that case want to be designed to sail at greater angles of heel). Rather, use a canting keel with some extreme depth and muscle it over manually, and stay vertical. This opens your options up to include any planing dinghy in the size range, though compensation for the ballast weight would require a bit more boat underwater (say, 2 1/2 cu. ft), and there are people here who could suggest ways to add that displacement into the shape, perhaps by such as something as simple as widening the hull a couple of inches. Alan |
| Less than 10ft? |
| Hopefully 12-14 ft. Long as you gotta trailer anyway... |
| the 10 ft is really an number off my head. light and portable in the bed of a pick-up truck (cartop) was the idea there. If it takes on a heavy keel it could well be longer due to the fact it will end up on a trailer. The main idea is something easly rigged and launched by one in a few minutes, read: less time rigging more time sailing. The canting keel idea is a great one. Since we are really not talking about a big boat I would think this would be easly managed with the proper purchase by one. I can see where this would lend itself to a flater hull design like a skiff. Would the weight negativley effect the plaining ability in light to medium air, thereby defeating the purpose of a plaining hull or would the increased sail area overcome the weight and put the boat on plain. Devon |
| witht the ballasted keel it would trailered. That is of little issue a small trailorable would be fine. |
This would be a rather dynamic ride. The light hull will react fast, and so must you. I would say you might get away with a sailplan of 140, which is extreme for a +/- 12 footer. The canting keel is an engineering trick, so the entire rig might be designed in a box that can be raised by a halyard at the ramp using a purchase of at least 2:1. What's left in the boat is a rectangular hole and a view to the water. Much like a plug used to cover a hole for an outboard mounted inboard, except a bit more complicated. What you cannot do is raise the keel to run downwind. Nor can I figure out how you will supply the power to shift the ballast, though spilling the wind and shoving your weight to the windward side down to the gunwale with the keel released would work--- pumping the boat itself, which just might work in a small boat. You wanted adrenalin, right? |
| Performance Dinghy Do a search for some of the perfomance dinghy threads in the "Sailboats" section of boatdesign-several of them. There is also a recent thread about an 18' canting keel boat-with specs and picture. Sounds like you might be interested in something like the Bongo but with a canting keel instead of a fixed keel. Of course, the lightest,hardest to sail and pretty nearly the fastest saiboat(mono or multi) under 20' is the incredible foiler Moth. But that may be a tad too much adrenaline and definitely not too good for two. Bongo (retractable) Keelboat Address:http://www.sailabongo.com/m/_general...eport=11&CAT=1 ---------- 18' Canting Keel Single/Doublehander - Boat Design Forums Address:18' Canting Keel Single/Doublehander |
| i will check out the threads you suggested, I really am not interested in re-invinting the wheel. If there is a boat out there that will do most of what I want thene great. The Moth...... what a cool boat, but not really quite right..... but cool none the less. That is the idea though an adreniline ride for one and one that I can build, again this is more about building a boat than sailing one. This canting keel idea is sounding better all the time. The idea of gaining the same righting effort as that of another crew would be just the ticket. Thanks for all your help. I agree finding a hull design I like then making the mods would be a reall way to go. Thanks guys. |
| on the subject of the canting keel, what kind of effort are we talking about to move the keel to windward. could this be done by hand with enough purchase without having ten miles of line to pull it into place? Or maybe a small selftailing winch? A sigle handed boat such as we are talking is going to be a hand full( and a mouth full as well tiller in teeth with main and jib sheet in each hand). Could the keel be eased before a tack/jibe manouver then when the tack/jibe is finished and sheets can be cleated, move the keel into position? |
| talk about re-inventing the wheel.... The bongo is just about everything I want in a boat. So there it is someone beat me to the punch doesn't fill the need to build. but it is definetly a great looking boat. |
| There are a couple of other possible boats that deserve a look and easily fit that go-fast vison you have in mind. The Swift Solo http://www.westsystem.com/ewmag/21/index21.html The new boat being made available from the Northwest Maritime Center, the PT15 dsigned by Paul Bieker. http://www.nwmaritime.org/news/news_128.shtml The Swift is geared towards the solo sailor and the PT15 for crews. Both are buildable. You'll have to check with the NWC above to get the current status for building a PT15 for yourself. Still, any boat that has the performance imprint of Paul Bieker on it is pretty much gonna be a quick boat. Dude likes to go fast. |
Might take a couple of seconds. The force requirement could be reduced of course, take longer (maybe less time if just right). |
| alan, Do you spend alot of time at night staring at the ceiling when you should be sleeping. You have an imagination, the foot petal would be a really great idea once again. your feet really wouldnt be busy until the boat powered up and you need to slide out to hike or trap. Interesting thought |
| the swift looks like a good boat, I have looked over the internet for single handed performance boats and really didnt find much, through this forum I have come up with some great ones. And a wonderful discuss on an interesting modification. A Bongo with a canting keel. The solo may be a near future boat that seems very do-able. Thanks guys |
| is anyone using SPAN for sailing yachts performance? | yades | Software | 3 | 09-23-2006 10:29 AM |
| Wanted to buy- small dingy/tender in Melbourne Australia. | hansp77 | Marketplace | 8 | 09-17-2006 06:59 AM |
| Sugestion for thrilling Sailing Dingy | Yacht Skipper | Sailboats | 24 | 08-05-2006 04:01 PM |
| building a small sailing/rowing dinghy need plans | Jeffrey Ashe | Wooden Boat Building and Restoration | 3 | 08-19-2004 02:43 PM |
| Dingy Plans - Wayfarer-ish | aitchem | Boatbuilding | 3 | 10-27-2003 01:26 PM |
