Old 10-10-2005, 06:54 PM
chandler chandler is offline
Rep: 16 Posts: 378
Small outboard skiffs
Any ideas for a 10' or so skiff??
Shallow draft, capable of carrying 8 hp 4 stroke, to run fairly level at slow speeds before planing.
Old 10-11-2005, 09:21 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,728
http://angelfire.com/ego/lewisboatworks/
LilJon, Poorboy, Fisher10 (my favorite) all free.
Old 10-11-2005, 07:14 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Why not pick up a used 10' aluminum boat. Grummans are very good. Hang a 8 to 10 hp on it and fly when needed? We have 3 of them.
Old 10-11-2005, 11:45 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Pretty easy to find a slightly banged-up Springbok, Grumman, Starcraft or what-have-you in this size, for very little $$. Often one will start leaking and will come on the market for only a few hundred bucks, the owner not realizing that the leaks can be easily fixed in an hour by two guys with 10lb sledgehammers. So this is a good route to go. If you want to build one yourself, check out http://www.instantboats.com/boats.html (look at the Pointy Skiff and the Skimmer) or the ever-handy Glen-L plan banks.
Old 10-12-2005, 08:24 AM
Seafarer24 Seafarer24 is offline
Sunset Chaser
Rep: 22 Posts: 203
Good post above. I picked up a 14' Starcraft from the '70s that has a slighly banged up port bow, but tracks straight and doesn't leak, for $50! For $200 I got a used Mercury 110 (10HP) that needed a new prop (another $150-ish). Then a crappy but usable trailer for $100. I built a plywood deck with anchor locker and very large storage area that covers the first 6' of the boat and re-shapes the bow close to original. The rear of the boat is getting a styrafoam/fiberglass U-shaped seating area to hide the gas tank and provide room for a battery and fishing poles. I may eventually re-do the front deck in foam/glass as well.
Old 10-12-2005, 06:18 PM
Rep: 16 Posts: 378
Thanks guys.
That's what we have now. With an 8 horse 4 stroke you have to sit in the middle of the boat until it planes in order to keep the stern from squatting so much that you can't see over the bow. Any ideas about balancing such a boat?
Chandler
Old 10-13-2005, 12:14 AM
What is the present boat lenght. 4 stroke must weigh a ton compared to a 2 stroke. Has to.
Old 10-13-2005, 10:17 AM
lewisboats's Avatar
Obsessed Member
Originally Posted by chandler
Thanks guys.
Chandler
What about one of those fins that attach to the lower leg of the OB? You can also try tucking the motor in a little more to push the nose down, but this slows you down somewhat. You might even try rigging some kind of trim tab that you can push into the water to push the nose down until you get to planning speed. What kind of boat are you pushing with the motor right now?
Steve
Old 10-13-2005, 12:12 PM
Our 12' Aluminums with old 8s or newer 9.9 are on plane with my 200# in 2 to 3 seconds with anchor and plenty of fishing junk. Something is not right with yours. I have a 16' Lowe that is easily 750# and a 1990 9.9 hp that can plane the 2 of us in 4 seconds. Get some good locals to find the problem.
REALLY small cruisers... Sean Herron Boat Design 23 09-28-2006 12:59 PM
Roll Instability on small outboard boat? RThompson Powerboats 14 06-09-2006 02:08 AM
The size of a small outboard... ErikG Boat Design 3 08-09-2005 10:05 PM
Small Boat Program Coordinator needed CDBarry Services & Employment 0 02-10-2005 11:31 AM
