Old 06-19-2007, 05:47 PM
Sooty Sooty is offline
Rep: 10 Posts: 4
Small Hydroplane centre of gravity/balance point??
Hi Chaps
I have a small (3.5mtr) racing hydroplane to which I need to add some ballast to meet class racing rules.
The thought of where to I put the lead has made me wonder "where do I put it?!"
Is there a set formula for working out where the static centre of gravity should be?
Any help, guidance, answers really appreciated.
Sooty
Old 12-28-2007, 05:25 AM
Victor Lemmi Victor Lemmi is offline
Rep: 10 Posts: 10
design
Hello!
How didi you get the plans?
I would like to build one similar
Tks
Happy new year
Victor
Old 12-28-2007, 09:27 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
I don't have your answer, but I'd like to think out loud for a moment if you do not mind too much.
1. Adding all the weight to the center of buoyancy is a fine solution if you always plan to be at rest.
2. Adding all the weight to the center of lift as located while up on plane at a steady top speed may not reflect the "shift" which may occur from deceleration and acceleration as the result of resistance/torque caused by the water.
3. If I recall correctly, getting up over the "hump wave" at the starting line is very important, maybe this is one aspect which should be a priority when locating the weight.
4. One may locate the extra weight at or just below below the center line of mass to enhance stability and help prevent it from becoming top heavy.
5. On such a small craft operator/pilot leaning and shifting of weight may be an important control factor (it is in small hovercraft). Do the rules allow for the weight to be in added the form a weight belt? If so, being able to move or shift the weight could be an advantage at start up and at plane out and especially in turns.
6. Take any friendly advice you can from old timers and racers who are not directly competing against you or who are helping out another team. Weigh the advice carefully, everyone has an opinion and not all are equal.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 12-28-2007, 05:05 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Originally Posted by Victor Lemmi View Post
Hello!
Tks
Happy new year
Victor
There are some older, free plans here that might interest you...
http://www.svensons.com/boat/
Center of Gravity Gene H Boat Design 2 03-01-2007 08:58 PM
any software for finding the lightship weight and position of centre of gravity pavel915 Software 4 12-27-2006 04:20 AM
Rotate pulleys using gravity. Jigar111 Propulsion 18 12-02-2006 12:12 AM
small fiberglass hydroplane molds CHEAP mitchblack Fiberglass and Composite Boat Building 5 05-30-2006 01:03 PM
Longitudinal Centre of Gravity (LCG) jileateta Boat Design 2 02-02-2005 11:06 AM
