| Small asymmetric power cat I'm building a 4mtre cat for small twin Seagull engines. The deadrise is shaped to rise in the water but not plane. After reading possibly every opinion reg the virtues of flat vertical inside hull sides, I still have not found what this configuration would do to the steering or speed and what the hull spacing should be - for this application. Would there not be any bow wave between the hulls? Thanks gents . . . ps the motors are to be situated mid (through) hull, behind each crew. Last edited by rosbullterrier : 01-24-2010 at 05:54 PM. |
| I'd think in terms of two racing sculls connected together at whatever the min recommended width is. Isn't it 19.5 degrees off the bow? |
| Oh dear ,nobody interested - I did put it in the catamaran department - it got moved! Does it fall between stools - not big enough as a power boat and unlikely for Seagull racing . . . All I need to know chaps is whether there are bow waves at speed up to say, 15mph, between the hulls if they are straight vertical sided. Certainly I can, and will , build it and experiment, I'm just trying not reinvent a wheel or have to repeat your valuable experience! If it were a planing boat it wouldn't matter; its the possible wave resistance to determine the possible benefit of vertical inner hulls . . . |
| Sabahcat - the very man - I was just about to find how to send you an email. I was very impressed with your duflex 10', 'small powercat dinghy'. It would appear exactly what will work for me, you were inspired. I am very embarrassed to have copied the assembly without paying you - most others want money for their designs . . . Would it be a cheek to ask you the very question for which I'm searching - what is the advantage of the flat straight hull side in your asymmetric design? You've made and tried it, does it remove the bow wave and allow the hulls to be closer together? Yes, thats the Seagull engine. Shiney one you've got there. I'm placing the Seagulls through the hull floors half way back. The steering will be interesting . . . |
| New power cat - help please! | foxfish | Multihulls | 95 | 05-07-2009 04:44 AM |
| asymmetric spinnakers | Daz925 | Sailboats | 4 | 03-21-2009 09:57 AM |
| Asymmetric hulls | Trevlyns | Multihulls | 26 | 12-15-2006 03:36 PM |
| power cat | boatfan | Boat Design | 4 | 08-21-2005 10:37 AM |
| Small Power Cat Design | small cat | Boat Design | 21 | 08-26-2004 03:53 PM |
