Old 04-18-2006, 09:17 AM
eightwgt eightwgt is offline
Rep: 10 Posts: 22
Sliding in turns -PLANING HULLS
I have a questrion for the experianced designers here. What are your thoughts about reducing a planing hulls sliding thru a turn. I am reffering to small hulls 14-18' with an almost flat bottom.
What can be done to minimize this ?
Rounding the chine ?
Strakes ?
'Reverse strakes' at the chine ?
Thanks - I look forward to input.
Old 04-18-2006, 09:22 AM
FranklinRatliff FranklinRatliff is offline
Rep: 84 Posts: 294
Sliding
Strakes ?
It's called a skid fin. Unlimited hydroplanes have been using them for decades.
Old 04-18-2006, 09:38 AM
Rep: 10 Posts: 22
I should have addressed that - "No skid fins"
I am reffering to a typical recreation boat-think fiberglass Jon boat - not a performance hull such as a hydro...
Thanks - I appreciate the input -
Old 04-18-2006, 09:41 AM
Rep: 84 Posts: 294
If you're going fast enough to be sliding in a turn, you're going fast enough to be thinking about a skid fin.
Old 04-18-2006, 09:45 AM
Rep: 10 Posts: 22
Franklin
Thanks - I agree, however I am looking for other ideas
Old 04-18-2006, 10:28 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
You might get a little insight if you read this whole thread.
http://boatdesign.net/forums/showthread.php?t=11121
jehardiman; At most planing boat speeds, side velocity due to a turn is negligable compared to ahead velocity. While a jet boat can achieve significant side velocity in a turn , it is unlikely that a propeller driven craft can. But Yes, if you somehow managed to break a conventional powerboat into a sideslip without flipping it, then the prop will provide significantly less thrust due to inflow AOA effects. I mentioned it because it is a common proplem in auzimuthing pods. Turn the pod at right angles while going fast and you don't get the response you expect
Old 04-18-2006, 10:35 AM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
To stop sliding in a turn, you must have some lateral resistance. Messing with the chines is not the best way. Strakes near the centerline of the bottom like a keel will do the job. One strip on center will be most efficient but two off center is easier on dragging the boat around on the beach. You need to make trials to determine how deep they/it need to be. Stop the strakes well short of the transom (14" or more) or the prop will ventilate on turns. Strakes on the chine can flip you over on a flat bottom boat. The easiest solution is a skid fin but they can get in the way.
The long keel or strakes may also help in making the boat bank inward in a turn.
The worse thing is to have the boat slip in the first part of the turn and then suddenly grab hold. Better have on a good life jacket. Done that on a speedy flats boat and cracked ribs are no fun.
Tom Lathrop
Old 04-18-2006, 11:53 AM
Rep: 10 Posts: 22
Tom
Interesting reply.....
A flats boat huh ? Which one if ya dont minf me asking ? You can send a private reply if you prefer also...
The hull Im working on I know will have sideslip due to the nature of the hullform.... I was simply looking into ideas to safely limit it if possible.
Old 04-18-2006, 06:48 PM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
bin there done that many times. I throttle so its my fault.
Can anyone spare any gas today for a hamburger on Friday ???
Old 04-18-2006, 10:46 PM
This particular boat was designed and beautifully built by John Martin of Charleston, SC. He was experimenting with skegs to control the unnerving skids and had installed two parallel ones off center. We were running pretty fast, how fast I don't know but d***m fast and showing off a bit after a big fast boat tried to outrun him. He went into a full bore turn and everything was OK for a while although the boat was skidding quite a bit when it suddenly dug in and I catapulted across the boat. Non tripping chines would have helped too and the lack of them may have been the major fault in this situation.
Maybe I was only bruised rather than busted but a strong lesson anyway.
"Good judgement comes from experience.
Experience comes from bad judgement."
Tom Lathrop
Old 04-19-2006, 08:18 AM
Rep: 10 Posts: 22
Tom
What do you define as a "non-tripping" chine ? I am not sure I understand what type of chine you are reffering.
Thanks again
Old 04-19-2006, 09:46 AM
Looking at the boat from aft, the bottom will have a portion of the width turned up near the edge. This keeps the chine from digging in when the stern slides sideways in a turn. Don't forget that the stern of boats with the propeller in the stern always slide sideways in a turn.
Tom Lathrop
Old 04-19-2006, 01:35 PM
Rep: 10 Posts: 22
Tom
How much of a turn up ? Do you have an example I can look at ? This sounds like a good idea to incorporate into my project.
Thanks once again - it is appreciated
Tom
Old 04-19-2006, 04:00 PM
I don't know of a fixed number but you can look at the link below. The view of the stern gives an idea of how it was done on this boat.
http://www.woodwindyachts.com/Restor...orpedoRest.htm
Tom Lathrop
Old 04-19-2006, 04:40 PM
Rep: 10 Posts: 22
Interesting..... Thanks.
Take a look at my example.... A-B-C-D "A" being 'standard'....
Stepped Planing Hulls/small sailboats Doug Lord Sailboats 34 01-28-2010 05:41 PM
planing catamaran hulls/sailboat terabika Boat Design 16 06-02-2009 09:20 PM
Faster upwind tacking by taking turns towing? h.t.hall Sailboats 17 06-24-2005 02:49 AM
Book about fast planing hulls fede Boat Design 12 06-07-2005 09:03 AM
sliding window handle erie1 Powerboats 0 03-02-2005 07:28 AM
