Old 08-22-2008, 01:37 PM
weissmarine's Avatar
weissmarine weissmarine is offline
Rep: 10 Posts: 22
Sit on top surf kayak design
I have just popped the hull off the mold. Went 3 layers of glass (cloth, mat, cloth) used poly resin just for economical purposes. Definetely some flexibility issues. Do I need to add more glass for stability? Would epoxy resin add more stiffness? Should I use closed cell or mini cell foam into the hull for added floatation and stability? When adding and glassing the deck will this help with the hull from flexing?
Old 08-22-2008, 02:37 PM
xsboats's Avatar
xsboats xsboats is offline
xsboats
Rep: 10 Posts: 19
Addition of foam core and glass tape frames has stiffened lightly laid up whitewater kayaks I have built and should work for you without adding significant weight to your hull. I have also used carbonfiber yarn with a glass tape covering. Seam taping the hull to the deck should add the longitudinal rigidity needed.
Old 08-22-2008, 04:10 PM
Rep: 10 Posts: 22
Cool man, thanks for the reply. Any leads on foam core and carbonfiber yarn purchases? Kind prices.
Old 08-22-2008, 05:35 PM
xsboats's Avatar
xsboats
Rep: 10 Posts: 19
ask Mark at Sea Island Boatworks in Mt. Pleasant. He builds some nice cats and is knowledgeable about materials in your area.Scott
looking for a kayak design Grizz Boat Design 8 09-02-2008 07:42 PM
Kayak Design mut Boat Design 18 03-01-2008 05:22 AM
Max Surf Hull Design Zeus Software 4 11-30-2004 07:07 AM
Sit-on Kayak out of Foam? Otter Boatbuilding 8 08-15-2004 07:17 PM
kayak design amazingbeasts Software 3 02-20-2003 02:25 PM
