| Single Sterndrive Offset Hello, here it comes,the good old 1.000.000 $ question,hope someone is able to give an answer based on direct experience. We are in the process of installing a single 450 hp sterndrive on a 25' Racing Rib. The prop is a 28 pitch and the engine delivers 450 hp (+ or - ) @ 5800 rpm,reduction 1.5 Rib dimensions are: 25 lenght 6.3 beam (inflatables excludede) 8.4 beam including inflatables. I have to mount the sterndrive with an offset to contrast the turning effect created by the prop thrust and high power of the engine. The prop rotates clockwise so i would offset it's location to port...and now the 1.000 k $ question: how much??? Once the hole is done is done and it's not possible to apply trial and error here.... Thanks to everyone who will give it a try as usual! |
| c'mon guys!! I know you can help me! |
| why not a BIII duoprop? |
| Thanks Yipster,we already took in consideration the bravo 3 ,unfortunatly we have to use a bravo XR capable of more than 400 hp bravo 3 limit is @ 400 hp (and it's related torque) and the engine delivers more than that (more than 450 hp) Plus, Bravo 3 has gear rations from 1.8 up. |
| Sterndrive installation | Danielsan | Sterndrives | 14 | 04-27-2006 08:01 PM |
| Offset single prop - which direction? | Ben Lindenberg | Propulsion | 7 | 11-10-2004 01:53 PM |
| Problems with creating an offset file with autoship | koen | Software | 2 | 08-06-2004 04:37 PM |
| hull offset data... | wawa | Education | 0 | 08-03-2004 04:08 AM |
| Sterndrive question | duluthboats | Powerboats | 10 | 08-29-2003 11:12 AM |
