Old 03-03-2005, 08:56 AM
Coen Coen is offline
Rep: 39 Posts: 30
Simpson's formula
Hi y'all
As I wrote before, we are designing an offshore support vessel. We thought we finished drawing the lines plan, but according to rhino there is quite a big difference between our calculated immersed volume and the immersed volume calculated by rhino. The frame surfaces are equal, which makes me think that we are doing something wrong in our calculation. I will give you the facts:
Lpp = 59,4 m
We have 12 ordinates, spaced 9 frames between. As the frame distance is 600 mm this leads to 5400 mm between the ordinates. The ordinate surfaces are as like this:
Ordinate Surface
Old 03-03-2005, 09:28 AM
DaveB DaveB is offline
Rep: 11 Posts: 128
Lpp = 59,4 m
might be a good idea to post the 3dm file and spreadsheet.... have you checked the direction of your surface normals? Is it a closed surface?
I'd be happy to use rhinomarine (phaser) to get a displacement if you send me the file...
Cheers,
Dave
(fireball682@hotmail.com)
Old 03-03-2005, 11:15 AM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
Simpson's Rules (and others)
Old 03-03-2005, 12:11 PM
Palmer Palmer is offline
Rep: 10 Posts: 53
Simpson's requires an odd number of ordinates. IF you don't want to redefine them you could use the Trapezoidal rule instead. It's not quite as accurate as Simpsons but should be within a couple percent.
Old 03-03-2005, 12:17 PM
icetreader icetreader is offline
Rep: 12 Posts: 189
The metric system is really easy!
-I still use my fingers
fishing kayaks
Old 03-03-2005, 03:32 PM
Rep: 39 Posts: 30
Hey guys,
I'm am sorry to say, my thread was a mistake. While I was writing it I decided to go to the teacher and ask him
Accidently I probably pushed 'submit'. Thank you very much for your replies anyway.
When I have an answer I will let you know!
Tnx again,
Coen Meerbach
Old 03-03-2005, 03:40 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 484
In Rhino, Phaser, check: Help-> Plug-ins-> Protheus Hydrostatics and Stability Plug-ins-> Checklist. It's all there. In the beginning I made many mistakes, which solved by these notes.
Terho
formula jr. thunderbird need info Ron F Powerboats 53 04-14-2011 04:03 PM
Sail Boat Formula pmusu Sailboats 4 06-04-2005 05:47 PM
Universal Displacement/Length formula sharpii2 Boat Design 0 06-04-2004 02:51 AM
Simpson's Rules (and others) Mike D Boat Design 13 05-27-2004 07:59 PM
denny-mumford formula reference marielee Boat Design 0 04-02-2004 12:09 AM
