Old 11-02-2004, 05:50 AM
Alik's Avatar
Alik Alik is offline
Rep: 1020 Posts: 1,893
Simplified stability estimationfor powerboats
Working on method to estimate powerboats initial stability.
I propose diagram to estimate lever of form to chine beam ratio (Lf/Bc) depending on:
- chine beam to hull draft ratio (Bc/T)
- deadrise angle 0,5,10,15,20,25
- heel angles 5, 10, 20 deg.
These graphs are intended for planning powerboats.
Lf/Bc=f(Bc/T, deadrise, heel)
Lever of stability You can calculate like this:
L=(Lf/Bc)*Bc-Zg*sin(heel)
L - lever of stability, m (=GZ)
Lf - lever of form, m
Bc - chine width, m
T - hull draft, m
Zg - vertical center of gravity from baseline, m (=KG)
Please, test on Your designs and make comments.
Old 01-07-2005, 11:41 PM
Alik's Avatar
Test and advice...
Paper on stability estimation is almost ready. Please, advice in content and correct English. This papaer is supposed to be for conference, but method aimed at practical use.
Incredible "Secrets of Yacht Design" website located... pkoken Sailboats 579 10-09-2005 08:33 PM
Directional Stability Wardi Sailboats 9 06-01-2005 02:10 AM
Understanding Stability and Trimming Calculations Brian Boat Design 0 07-27-2004 02:38 AM
Full Displacement of semi tdamico Boat Design 51 02-18-2004 10:42 AM
Sailboat stability... ErikG Boat Design 7 11-30-2003 12:53 PM
