Old 03-17-2004, 11:42 AM
bevan bevan is offline
Rep: 10 Posts: 16
simple question
how would you move the centre of buoyancy on the hull profile of a catamaran?
Old 03-17-2004, 05:06 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
THat is not a question with a simple answer.
2 choices:
1.) Get different hulls
2. ) trim the boat to achieve what you want, and get used to comments about it's being out of trim.
3.) Add some sort of "Bump" to the hull to move the LCB. Allow for the weight of the bump when calculating it's placement.
Steve
Old 03-19-2004, 12:02 AM
tspeer tspeer is offline
Rep: 1313 Posts: 1,523
Same way you do it for any boat: change the sectional area curve of the demihulls. To add volume, you can make the sections wider, deeper, or fuller.
I like to start with the center of buoyancy and displacement, then work backwards. From these parameters you can define an area distribution from a family of area curves. Then define the general shape of the sections. Finally, scale each section to match the area curve. The shape of the hull falls out from these choices.
Details at http://www.basiliscus.com/CaseStudy/geometry.html
Tom Speer
Old 03-21-2004, 10:04 AM
SailDesign's Avatar
A note of clarification - I was assuming that actual catamaran hulls were involved, Tspeer is assuming a lines plan is being developed
simple question Leron Software 4 06-16-2007 09:56 AM
Book recommendations, and a simple question. Am I crazy? jstcrzyengh Fiberglass and Composite Boat Building 4 09-07-2005 05:35 PM
Simple question relating to canoe displacement cumbrian_matt Boat Design 5 07-04-2004 04:59 PM
simple Question huw Boat Design 1 03-04-2004 05:40 PM
Have simple question Sgray Boatbuilding 7 10-28-2002 11:28 AM
