| side girder manholes Is it available to make manholes in side girders for small vessel (40m length) build under BAS rules? This point is not covered in rules (for center girder it is not available) |
| You can Cut manholes on Side girders. As a practice, ensure that vertical extend hole is less than d/2 (d= depth of girder). Refer following part of ABS Rule for Center Girder. Same guidelines may be applied for Side girders. Part 3 Hull Construction and Equipment Chapter 2 Hull Structure and Arrangements Section 4 Bottom Structure 1.3 Center Girder "Where the girders are not required to be intact, manholes may be cut in every frame space outside the midships three-quarters length; they may be cut in alternate frames spaces within the midships three-quarters length. " |
| ABS (bottom hull girder section modulus) | Hisham | Boat Design | 24 | 06-11-2009 04:05 AM |
| canting keels: how are they displaced from side to side? | Thaddeus | Boat Design | 5 | 10-02-2005 04:22 PM |
| side by side centerboards? | Ian | Boat Design | 8 | 01-02-2005 08:24 PM |
| Left or Right side views? | S Hondros | Boat Design | 1 | 10-17-2004 03:05 PM |
| the far side of the world movie | yipster | Open Discussion: All Things Boats & Boating | 2 | 12-21-2003 09:07 PM |
