Old 07-28-2007, 03:25 AM
masonpowers masonpowers is offline
show me my new boat!
i work as a boat builder and am now at my witts end!!!!
sick of building every one elses boat!!!!!!!
time for my own.
but i want somthing different
somthing not seen
a new design!
if any of you budding designers out there hav a CAD boat you want to see fleshed out in the real world then show me what you got.
even if its just a shell thats fine.
i am looking for either a big power cruiser or a displacment cat.
30' min 42'max
more a relay and chillout boat
so can anyone help?
Old 07-28-2007, 05:03 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
This one is just a shell, design obviously not finished:
It's a simple hull design for a 31 foot double-ended displacement power boat ... a beachable shuttle boat or small ferry for use directly from the local beaches and between the islands.
With modification I'm sure it would become a very comfortable cruiser, and its Seabright skiff heritage should make it a very seaworthy boat as well.
31 feet in length
9 feet 6 inches beam
Waterlines shown:
12 inches at 4600 pounds displacement
18 inches at 8000 pounds displacement
I used the Seabright skiff bottom for safety when running through the surf and for sitting stable and upright when landed. I also made it an easy beach-loading craft via its unusual bow transom which opens downward to become a loading ramp, while the stern transom will have a safety re-boarding ladder on it.
Larger image here:
http://www.bagacayboatworks.com/link...aft31large.jpg
Kenneth Grome
Old 07-28-2007, 06:06 AM
raw raw is offline
Rep: 59 Posts: 133
This is a 34 ft concept that never came about in the end. It got a lot further through preliminary design, than this so I do have more information at hand.
I don't think its what you are looking for, but hey you asked.....
Old 07-28-2007, 07:39 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
bit bigger, but have a look at this concept
Old 07-31-2007, 05:14 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
Masonpowers, what material are you looking to build in? If your comfy with composite & have realistic budget I have tooling for 41' displacement sail cat, my NA "may" be happy to redraw & calc to power configuration, if thats in your line pm me for more detail. Regards from Jeff.
Old 08-29-2007, 11:13 AM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
Hi Mason,
I am curious to know what the term relay boat means.
Thanks
Old 08-30-2007, 03:52 AM
waikikin's Avatar
Gilbert, typo i reckon y in plce of x. regards from jef. PS: he aint posted since.
Old 08-30-2007, 09:35 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
30 ft trailerable MotorCruiser
Steve
Old 09-07-2007, 01:47 PM
SkipperSki SkipperSki is offline
Rep: 10 Posts: 11
You might want to check out the Calkins design, of the Bartender, double-end Surf Dory. While they are light weight in wood, Aluminum ones have been built, for C.G. and some Oil companies.
I'm thinking of building a 34 footer, sport-cruiser myself, but I'm just in the planning stages, to determine hull materials, of either wood, alum., or steel.
Old 09-11-2007, 01:06 AM
la cage la cage is offline
Rep: 10 Posts: 17
Consider building uses my method of construction I have developed over 30 years. The interior is built first inside a steel skeleton. I saved 3000 man hours building my 12m, yacht. Good luck from down under. Peter Bourne. www.bourneboats.com.au
Alternative method of boat building!!!!
Los Angeles boat show kerosene Open Discussion: All Things Boats & Boating 0 02-05-2007 12:22 AM
Boat Show Poida Open Discussion: All Things Boats & Boating 0 08-17-2006 06:40 AM
Miami Boat Show Pictures Tom Young Open Discussion: All Things Boats & Boating 2 03-04-2005 08:02 AM
Catamaran Charter Boat at Annapolis Boat Show catamarans Press Releases 0 10-06-2004 12:25 PM
Annapolis boat show stainglassboats Marketplace 0 10-05-2003 06:35 AM
