Old 03-21-2005, 09:02 PM
ohenry ohenry is offline
short shaft motor on long shaft boat
Fresh to boating and due to a bad purchase and tring to make a bad situation work I need advice. I have a 16 ft (thin/light) fiberglass V-hull side control with a 30hp johnson (rope start short shaft unknown age but works well). The boat needs a 20" shaft motor (not 15" which is on the boat) the trasome is about 18.5"! I would be content if I could mount the motor low enough without cutting the trasome or off setting the rear weight distribution to much. I have considered getting a jack plate / reversing it to drop the motor but fear the possibility of not being able to tilt the motor or the motor being to low in the water hence ? h2o damage.
ohenry
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Dennis Conner's newest America's Cup yacht sank Tuesday off Long Beach Jeff Sailboats 15 10-14-2004 09:20 PM
Boat choices... not specifically design related curtis73 Powerboats 1 03-26-2003 12:33 AM
geometry of sailing Sailboats 8 10-12-2002 11:58 AM
