Old 02-28-2012, 03:24 AM
thama's Avatar
thama thama is offline
Rep: 10 Posts: 7
shock mount
type of shock mount was to be selected for a console which weighs around 450kg. i have no idea where to start and the only information i have is the weight. any guidelines for selection of shock mounts?
Old 02-28-2012, 06:08 AM
daiquiri's Avatar
Engineering and Design
Rep: 2981 Posts: 3,499
What kind of shock mounts? Where are they to be installed?
Old 02-28-2012, 06:42 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 285 Posts: 603
This is the type shock mount typically found on navy ships for that application
Old 02-28-2012, 06:53 AM
daiquiri's Avatar
Is it an academic work or an inquiry related to a real-life boat which needs shock mounts to be installed?
Old 02-28-2012, 07:36 PM
thama's Avatar
Rep: 10 Posts: 7
Its for navy ships.
Old 02-28-2012, 07:41 PM
thama's Avatar
Rep: 10 Posts: 7
I have seen this kind of mounts regularly used for electronic equipment but i have no idea about the selection of the mounts as i have very little information. i only have the weight. Is it very risky to select this kind of shock mounts without proper calculation?
Old 02-28-2012, 09:22 PM
Rep: 285 Posts: 603
Weight, number of mount points equally loaded, how much deflection the spec is calling for = mount size
Steve
Old 02-28-2012, 09:26 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 2188 Posts: 3,730
Firstly you need to know what load/shock is being applied and the duration of the impulse and finally what is your pass/fail criteria.
For example, you may have items on the console that are fine if you have say....10mm of movement, others say 15mm. Thus 10mm displacement becomes your pass/fail. So the stiffness of the mounts is related to this displacement, as a simple spring constant.
Old 03-19-2012, 02:15 AM
thama's Avatar
Rep: 10 Posts: 7
thanks people. i actually contacted the shock mount supplier company and they could provide me the suitable shock mount with very little information given to them.
Installing a transom mount trolling mount on the bow prime winner Boat Design 1 02-05-2009 02:04 PM
hard mount or rubber mount? Razgo Inboards 16 09-09-2008 11:11 AM
Shock and Vibration data for Power (Sail?) boats ?? TerryKing Boat Design 0 11-28-2007 01:24 AM
Wake Shock brianjkirk Powerboats 0 09-20-2007 11:21 PM
Shock Cord nemo Sailboats 4 12-11-2002 03:05 AM
