Old 10-23-2007, 02:45 AM
anth anth is offline
Rep: 10 Posts: 2
ship design help
hello, i am currently a engineering student and doing a tutorial on tanker design using maxsurf and hydromax. We are giving the following info:
Waterline length: 310 m
beam: 51 m
design draft: 18.5 m
displacement at design draft: 251,800 tonnes
- at ballast condition, the draft is 11m and KG is 12m.
- at fully loaded condition, draft is 18.5m and KG is 17.5m
notes:
- model this tanker by starting with the 'VLCC' sample maxsurf design, and stretching it to the correct dimensions
- neglect free surface effects on stability
- the above-water profile area in ballast condition is 4960 m^2, with centroid 20m above the keel
It wants me to calculate the GZ curve for both conditions, so I've opened up the VLCC maxsurf file to change the dimensions but I don't know how to get the depth from the above information to enter into maxsurf?
Also I'm not sure why I was given the above-water profile area and centroid above keel for the ballast condition? doesn't maxsurf generate this?
Finally, a question asks me how strong a beam wind gust would be required to heel this ship to 1 degree when in ballast condition, i understand that I have to compare certain areas under the GZ curve to do this but was wondering if hydromax can do this?
any help at all would be greatly appreciated.
Thanks
Old 10-23-2007, 05:05 AM
Arvy Arvy is offline
Rep: 44 Posts: 114
Setting the depth in maxsurf
Hiya Anth,
You can set the depth through menu option Data -> Frame of reference.
Hope this helps.
Old 10-23-2007, 05:20 AM
Rep: 10 Posts: 2
ok I assume from the question that the DWL should be set to 18.5m. But I still dont know how to get the depth to put into the 'size surfaces' function?
Hydrofoil Ship Design Panos_na Boat Design 4 12-19-2006 11:34 AM
my ship design project and presentation pavel915 Software 4 11-30-2006 04:53 PM
Senior position in Ship Design vpkumar Services & Employment 0 05-23-2005 10:18 PM
buying ship design software Archive Software 30 01-17-2005 07:27 PM
Small Ship/boat Design Course BAN Education 2 09-25-2004 09:44 AM
