| Shell Stiffeners Is It A RULE That Shell Stiffeners Must Be Normal To Shell Plate? |
| I think you mean "rule". No, they can be at an angle other than 90 degrees.
__________________ Gonzo |
| But I Think Software For Modelling Shell Stiffeners ,model Them Normal To Shell. |
| Are you asking about framing for hull plating?
That is a software issue. Nothing to do with a "rule requirement". |
| It is more efficient from an engineering point of view, making maximum use of the stiffener material and avoiding creation of lateral forces that have to be considered and controlled. But if there is a reason for doing otherwise, just be sure to do it right. Most hull frames and bulkheads, for example, are not normal to the skin, they are normal to the centerline, so it's hardly unusual.
__________________ "Boats are like rabbits; you can have one boat or many, but you can't stop at two" - A. Onassis Boat designs: "a convoluted collection of discontinuous compromise" - Par ". . . ere the end, some work of noble note, may yet be done . . ." -Tennyson Dances with Turkeys Last edited by ancient kayaker : 01-29-2011 at 10:26 PM. Reason: "centerline" phrase added for clarity |
| John Gilpin Hi there I think there aren't any right answers to such a broad question. Structural engineers use tables that give them the bending strength (modulus) of various sections(z-tables). These are for when load is simply supported, like standing is the middle of a plank supported at either end. This is strength on one plane only. Obviously if the ribbing is angled, there is no longer bending in a plane, but other more complicated things to consider. It depends on what is connected to what. Anyhow right angles stiffeners would seem the most logical. Please see my stiffener plates. Cheers ![]() |
However, on large ships it is sometimes preferable to have bigger horizontal side shell stiffeners, rather than normal to shell plate, as they need only to be bent and not twisted, hence there is a building advantage.
__________________ "water always knows better" |
| dear nemo thanks a lot for your reply.really i want to make a 3d model of a ship and i want to start with shell and stiffeners on it.i have only approval plans as reference and the software (foran) don't ask me the angle of stiffeners and designer don't show that angle . what should i do? |
| longitudinal profiles on shell |
| shell longitudinal profiles Quote:
| Then you need new software. A ship designed like that may be correct from a computer programmer's viewpoint, but from a shipwright's it it an expensive nightmare.
| Depends on the software and how it copes with stiffeners and frames. But you should be able to do what you want. If the software wont let you..it is crap software. |
Read the manual! ![]()
__________________ All the stresses in my designs are 95% of permissible. |
| Rhino: Positioning Stiffeners in Bottom Panel | Willallison | Software | 16 | 12-13-2010 05:38 PM |
| Stiffeners spacing | DUCRUY Jacques | Class Societies | 2 | 08-22-2010 06:56 PM |
| Transverse/Primary Stiffeners | CanuckGuy | Boat Design | 2 | 12-22-2009 08:17 AM |
| BHD stiffeners | ringoo83 | Boat Design | 5 | 02-24-2009 04:52 PM |
| Racing Shell | loveforvdubs | Wooden Boat Building and Restoration | 6 | 05-11-2006 02:41 AM |
