| Shell expansion book reference? Anyone know of a good book that deals with shell expansion determining and drawing? I'm interested once one has a lines plan worked out, how does one determine and draw the shell expansion drawing. The maximum allowed dimension of the plates used in the yard is known at that time. |
| Not a book as such, but maybe you can gain some useful information from the PDF attached.
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
thank you for the PDF. Although it did not answer any of my questions, it is a valuable read, and gave me some intro into the matter. What I am looking for, specifically, are practical methods of how shell is developed on steel boats in the range 20-40m (if that matters). I have several more popular books on boatbuilding (Gerr, Goodwin) but not much info on that particular topic. |
| I think he's looking for a guide to expanded panel shapes. |
| Then i suggest you start with something like: "The Geometry of Sheet Metal Work", by A. Dickason published by Pitman. |
| Take a look at the two pdf files given by Tad Roberts here: developing hull panel shapes |
| A torch in a skilled hand can make sheet steel do back flips with a half twist. I think this is a case where some one is looking information about something, they have zero experience with, both from an engineering stand point (physics, simple geometry and material properties) and a practical level. It's one thing to read about rolling a plate and another to see an uncooperative edge, aligned by a well skilled welder and his torch. |
| True, PAR. But he is seeking info because he wants to learn. Perhaps he doesn't have a good artisan nearby to show him tricks with gas torch. Besides that, I don't think there is a reliable and handy mathematical model for permanent heat deformations, to be used in the design phase (you guys correct me if I'm wrong). It is still left to personal skills and experience of the torch-welder. If he doesn't have the necessary experience then it is better for the safety (possible high residual stress of uncorrectly bent and costrained plates) and quality of the final product to stick with the single-curvature developable plates. The former also require less time to manufacture and hence allow to keep the costs under control. Cheers |
| I want to be a dentist, is there any books to help me learn about root canals? |
| Sorry PAR, if I understood your point correctly I have to disagree with you this time. ![]() There was surely a time when you didn't know all the excellent stuff you do know now. At some point you have started to learn, though. One can learn from books, in the schools, from an experienced craftsmen or sailor, or (often a painful way) from personal experience. Most of times a single source is not enough because no single person or institution is a guardian of all the knowledge. But there is always a starting point in everything we do. The OP is asking for a good (which I read as - verified, reliable) book, which I consider a positive and constructive way to start a learning journey. ![]() Cheers |
| daquiri, Ad Hoc, thank you for the provided materials. I found Dickason's book on some "second-hand book site", ordered it for a few dollars, and am now waiting for it to arrive ... Have questions, hoping it will answer some ... As to the discussion between PAR and daquiri, let me just explain a bit. I don't know was it a guess, or his familiarity with this little part of the world, but daquiri explained it pretty correctly. I'm a relatively young nav. arch., from an inland town, where I studied. Although Croatia has its share of yards and even one college in a sea town, those of us who after college didn't start working in shipyards are sometimes left behind on some aspects which are usually learned by watching and learning from master workshop workers, and technologists. This can be said to be such a case. Unfortunatelly, good books on the subject are rare (as books on most shipbuilding subjects are, for that matter) and if one doesn't start within a yard, then he has to learn the painful way. So, doing my best here ... collecting every piece of info I can from people ready to help and explain ... (yeah, that's you and going from there ... |
| Shell Plate Expansion and type of forming process | Navdes_E | Boat Design | 2 | 02-08-2011 02:07 PM |
| Problem with Workshop (Shell expansion dwg) | NavalDesigner39 | Software | 3 | 09-26-2010 03:58 AM |
| Traditional Shell expansion drawing in Rhino | pavel915 | Software | 4 | 04-05-2008 08:22 AM |
| shell expansion and midship section drawing in workshop | pavel915 | Software | 5 | 02-27-2007 02:27 AM |
| unroll surface in rhino for shell expansion | pavel915 | Software | 4 | 02-16-2007 07:35 AM |
