  #31
Old 12-12-2010, 09:50 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
And here's Britton Chance camouflaging really high slab-sides with a wide boottop and matching sheer strake....Ondine III or IV....?
  #32
Old 12-12-2010, 10:20 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Question for those with real-world boottop experience:
Can a boottop profile which looks nice in a 2D profile drawing wind up looking slightly odd if lofted directly onto a hull witout any adjustment, particularly if it's a hull with a bluff bow or stern? Not suggesting it would always or even usually happen but seems to me it should be possible to get an un-intended powderhorn shape in the boottop.
  #33
Old 12-13-2010, 03:04 AM
Rep: 670 Posts: 2,457
Hmm...must be Ondine IV with the inboard rudder and tall mizzen that could be canted to windward. . So many Ondine's its easy to mix em up. Ondine III had an outboard rudder and was designed by Tripp ? cant remember...getting to old.
  #34
Old 12-13-2010, 02:46 PM
Bruce46 Bruce46 is offline
Rep: 49 Posts: 81
Tad in response to your posts I went back and looked for the origional note I got from Rod. After going through some old papers, I did find the original memo. They were not cast in stone and I'm sure that adjustments were made. The fromula appears to work better on longer boats as I did a 61' motor yacht and the formula bootstrip looks great while on a
42' motorsailer it is too thin, perhaps there needs to be a adjustment factor for the height of the sheer in relation to length.
As an aside I worked with Bob Harris on a couple side jobs while working at S&S
  #35
Old 12-15-2010, 11:32 PM
Rep: 49 Posts: 81
Please note the corrections to the boot strip formula that I posted.
Thanks
  #36
Old 12-16-2010, 12:12 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Thanks Bruce.......I agree there should be another factor for height of sheer and/or length of the boat.....but what you have provided can be a starting point for anyone, and I'm particularly pleased that both top and bottom are curved.....most of the time it's impossible to get boatbuilders to actually do this........now I can say..."well this is the way they do it at S&S"........
Bob Harris is an old friend and mentor long ago....he's well and living in Vancouver, retired and busy keeping the books straight in his housing co-op...he self-published a slim autobiography in 2008, Tracks on the Water, My Life in Yacht Design, ISBN 978-1-897518-81-6
You mention side jobs with Bob.....multihulls perhaps?
  #37
Old 12-17-2010, 10:08 AM
claydog claydog is offline
Rep: 37 Posts: 41
While i don't have experience with boottops I do work with putting 2d lines on a 3d surfaces every day and the answer to your question is yes it very likely will look a little odd. you also will get a slight powder horn due to the differing plan views at the top and bottom of the boottop. Masking tape is a great tool to layout and tune the lines before commiting to paint.
How do you find the waterline? help evilpriest Stability 2 07-15-2008 07:35 PM
How To Scribe A Waterline abckits Wooden Boat Building and Restoration 5 05-28-2008 07:33 AM
Find the waterline bentshaft Boat Design 1 03-16-2008 02:25 PM
Confusion Below the Waterline Texas Boater Wooden Boat Building and Restoration 2 05-20-2006 03:40 PM
designed waterline? huw Boat Design 3 06-05-2004 12:29 AM
