Old 05-02-2008, 09:00 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Sheer?
I'd like to know more about sheer.
It's purpose? I understand it adds to the beauty of the boat & helps ease the turning effort?
Is there a rule of thumb for designing it in? So many inches per length of hull?
What is the correct way to talk about it? If I say, "2' of sheer in 62', is that understood as the center of the hull is 2' lower than the bow or stern? Is there a better way to describe the amount of "dip"?
Is sheer equal, between bow & stern?
I hear of banana shaped hulls & how they are driven more efficiently. Is this a referral to the sheer?
Is there a difference between sheer in a power boat as compared to a sail boat?
Are there drawbacks to having sheer?
Inquiring mind wants to know. Thanks.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 05-02-2008, 09:36 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
Sheer has nothing to do with how a boat performs except where high ends or low freeboard factor in. Of course, with angled sides, beam is effected, so it is wider if the sheer is higher at the midsection.
In general, designing the sheer is an aesthetic problem. There are many different types of sheers; classic downward curving, reverse (humped), straight, s-curve, stepped, and so on.
Each designer has developed his own carefully nuanced sheerline.
There are some "formulas" as well, based on what has made certain classic designs shine.
I personally like to draw the lowest point of the sheer about two-thirds aft, with the bow maybe 4/3 higher than the stern, except on canoes and dories, which I prefer only slightly higher at the bow, and which have more symmetrical fore and aft profiles.
Practice drawing what looks just right without formulae, and then measure the results of the ones you really like, to get some kind of formulae that will speed the design process.
Alan
Old 05-02-2008, 05:47 PM
BOATMIK's Avatar
BOATMIK BOATMIK is offline
Deeply flawed human being
Rep: 190 Posts: 273
There are many great looking boats with concave sheerlines, convex sheerlines, dead straight sheerlines. Even ones with "S" shaped ones (I am thinking of some traditional craft here).
There is no rule. However the sheerline can be used to make a boat look much bigger or smaller in terms of volume.
"Nice" sheerlines are a purely cultural artifact - so it depends what boats you have been surrounded by during your life.
Best wishes.
Michael Storer
my boat pages
Old 05-02-2008, 06:38 PM
ted655's Avatar
Rep: 122 Posts: 641
Glad I asked. Basically, beauty is in the eye of the beholder, (or in this case, the designer).
I am surprised though. As i learn more about boat design, I learn that there is usually a sound, practicle reason for each element of design, a form follows function rule.
To think, the looks of a boat are given that much time & effort.
Go figure! Old Salts are "arteests" at heart.
Thanks.
Old 05-02-2008, 07:02 PM
amolitor amolitor is offline
Rep: 17 Posts: 87
There WERE lots of reasons for sheers to be the way they were. Working boats of various sorts typically have a need for low topsides, somewhere. Where, exactly, depends on the type of work. Classic also come from the natural shapes planks fall in to when you bend them to form the hull. Modern sheerlines are frequently about making more internal space without making the boat seem too tall.
Old 05-02-2008, 07:53 PM
BOATMIK's Avatar
Rep: 190 Posts: 273
Howdy,
Form following function is a load of rubbish.
People are continually confuse function with "conventional". And so we get into discussions about culture again.
Why did all cruising boats have masthead genoas in the 60s, 70s, 80s and 90s?
We know those sails are expensive (because you need several different headsails) labourious (requiring extra people and expensive gear - big winches). But it looked "Right" at the time.
Or the shock and horror when Illingworth sailed the flat sheered and short ended and high freeboarded (not to mention light displacement) "Myth of Malham" into the record books and revolutionised ocean racing.
Or John Spencer or Vandestadt with their light, cheap and possible to amateur build sheet plywood racing yachts which were banned by most ocean racing clubs when they could show they were much better boats. They looked completely wrong and both Spencer and V. decided the battle was too hard and headed off in different directions.
Or the upset from the yacht sailors when Farr and Whiting broke into that scene. Us dinghy sailors thought that they looked "just right" - the yachties were horrified at the appearance of the boats. They "look completely wrong" are "dangerous".
Or the non acceptance of multihulls in mainstream yachting from 1890 through to now. They just ended up creating their own sailing scene. "You can't have THAT going offshore".
Or the failure of the IYRU to accept the 10sq metre canoe as its single handed class when it won every race in the sail off selection trials. So now it is managed by the International Canoe Union (or whatever they call themselves).
Or when the British sailing canoists got burned to pieces by the Americans when they visited it in the late 1800s. They though it "unseamanlike" to sit on the sidedecks!!!! The Americans had no such qualms so whipped their sorry ...
Or the danger that was posed by having the rudder separately hung from the keel. "Dangerous", "structurally weak", "vulnerable". They neglected to mention it also resolved the wild steering problems of some short keelers.
Or Bolger's mucking around with canard rudders - or the follow up of Blackaller's canard 12-metre or the winged keel of Lexcen.
Or that wide flat "planing surfaces" aft and a long clean run were necessary for speed downwind and up. The Australian Skiff classes blew that out of the water a couple of decades ago (thanks to Julian Bethwaite and also the Moth designer/builders)
What "looks right" is purely 100%, completely .... what you are used to.
The things that make a boat go are a subtle mix of relationships and ratios that are not available to the casual viewer at all.
When a designer finally starts to see those relationships and ratios in a clear way (and it doesn't necessarily require that you pull out the calculator at all - often experience is enough - of both sailing and designing) then the real design starts to happen.
It is exactly that sense of "what looks good" that is restrictive and prevents progress in a real understanding of any type of design.
In general we are pretty flexible - when something comes along that does the job better we are usually a little shocked that it works so well but looks (ahem) a little odd.
However we quickly accept it and that in turn becomes the new restriction.
Just take a look at all the production yachts for general use that are reflecting Open 60 design themes. They look cool on the dockside, but a more miserable seaboat is hard to find. Hard to sail, the hull volume makes them bounce around. Because of the greater wetted surface they require bigger sails - which are expensive and harder to handle. Which requires a deeper keel which restricts the boats the water can sail in - or requires a really heavy bulb which increases the displacement which reduces the performance.
There is no form following function in such boats - they are a mere repetition of accepted norms - a verisimilitude of "performance" design - not an iota of original thinking in those themes. But geez they will look good at boat shows with the "take your shoes off before coming aboard signs" on the sidedecks and the vase of cut flowers on the saloon table (if it is a marina exhibition see if you can remove the blutack from the vase base while the salesman is not looking). "Look - daaaaahling - all that space!!!."
Best wishes
Michael Storer
my boat pages
Old 05-02-2008, 08:26 PM
BOATMIK's Avatar
Rep: 190 Posts: 273
Oh ... as far as sheer ...
These are my rules for a nice sheer
If you are designing in 3d look at it from different angles with the boat heeled in different directions to make sure it doesn't look uncool from any angle. Don't forget about sheerline on the far side of the boat either.
When designing 2D - put a bit more sheer in the ends than you think and when building the boat leave some excess on the top edge of the hull so you can stand back and walk round when the boat is upright (don't forget that most people will not be standing in neck deep water when looking at your boat) and set up a batten that looks nice - add corrections to the drawing later. If you have done a good job the sheer on the drawing will require very little adjustment.
Amolitor is exactly right about there being traditional reasons. Usually to do with getting loads aboard or providing suitable perches for archers or cannons or reducing cost and resources by reducing hull surface area without affecting seakeeping too much. Most of these reasons are irrelevant now but persist as cultural artifacts.
Best wishes
Michael Storer
my boat pages
Old 05-02-2008, 08:33 PM
Rep: 3125 Posts: 9,398
Easy Michael, switch to decaf for a couple of days man . . .
Sheer has become a generic term, that is applied to anything that has a sweep or curve to it, in the horizontal plane.
An example would be a cabin roof line that sort of follows the deck line. This line would be described as having a "complementary" sheer, meaning the roof line sort of mimics the deck line in a pleasing fashion.
There are practical reasons to sheering the lines on a boat. An upward sheer in the deck line produces a dryer boat underway, while at the same time reduces freeboard midship, making boarding easier. An upward swept stern, can keep a following sea from climbing aboard.
Conversely, too much sheer in the stern can cause a boat to march around it's hook in an anchorage or be difficult to handle in a stiff blow on a sail boat. Too much bow sheer can keep a boat from pointing too high, letting competition whip it's butt to windward.
There are many very general guides you can incorporate into a sheered line. The amount of rise, it's relation to the rest of the line or boat, location of the lowest point, quickness of the curve, etc. The list is quite long and frankly useless, in little more then a reference for classic shapes.
Most of the "conventions" regarding sheers are no longer used. As has been pointed out, each designer develops their own idea of the ideal sheer. Personally, I can recognize different designers work a half mile away, by the sheer and the visual clues, like bow profile, etc. I hope I'm not as predictable, but giving it some thought just now, I tend toward Indian head or plumb bows, similar foil shapes and rigging choices and I labor over sheer sweeps a great deal. Maybe 50 years from now some one will pass a puddle and say, "hay, look a PAR design." . . . "I can tell by the ugly bow and funky sheer" . . .
As far as accepted norms and form following function, I see two avenues. One peruses sales, in which anything goes. Form follows marketing trends in these cases. In the other is clever engineering and invention. From the crab boat that develops a special winch to haul its pots to a racer that reduces windage by placing it's turnbuckles below decks, all functional elements, which will be followed by the folks that hadn't thought of it yet. It may not be necessarily correct for each application, but how do you know unless you stub you toe on the thing in the middle of the night.
Old 05-02-2008, 08:56 PM
BOATMIK's Avatar
Rep: 190 Posts: 273
:-) PAR,
I am inclined to be more one eyed on this!
Focus on function and let the form take care of itself.
People might not like the result .. but they will grow to like it if the function is noticeably superior.
If Spencer and Vanderstadt had been accepted by the mainstream clubs and the general Yachting establishment the history of boat design would have been much different.
There would have been an era of cheaper, faster, easier to build ocean racers and cruisers with good righting moments and easy to handle fractional rigs.
And everyone would have the "chine" as the universal standard of beauty.
(I would probably be spending my time designing round bilged boats just to show em!!!).
"C'mon guys ... these things have real advantages"
"But MIK, they are sooooooo 1870's"
Best wishes
Michael Storer
(PAR knows I am really too lazy as a boatbuilder to be bothered with round bilges - and as a designer I wouldn't force something on other people that I am not prepared to do myself)
my boat pages
Old 05-02-2008, 09:19 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
OK, I got it, the purpose of sheer is to stop the gunwales from fraying at the edge. It's just easier to make it a smooth curve instead of a saw-edge. Right?
Old 05-02-2008, 09:24 PM
ted655's Avatar
Rep: 122 Posts: 641
I think you misread me.
====="Focus on function and let the form take care of itself."=========
. I said the same thing. Form "follows", (as in comes last, behind, after), function, (as in, IT is more important).
Anyway, I'd much rather something work well, last longer, than look good. A rare event here in the USA. As a culture, we want it fast, cheap, & COOL looking first. Even better if it is short lived or can be made obsolete in a month.
Anyway, I'm getting an ear full about "sheer", thay's the best part.
Old 05-02-2008, 09:46 PM
BOATMIK's Avatar
Rep: 190 Posts: 273
Howdy Ted,
I guess my main point is that there are no rules or guidelines.
And maybe I am saying that function follows function. Appreciation of form is something that happens after the fact and that appreciation is a malleable thing. Function you can trust - form is fashion or culture.
There was also a bit of a feeling that you were allowing an aesthetic form be a guide to correct function.
I don't agree - but I might be wrong about what you meant - and I might be wrong too!
I think that what you said cut to lots of important issues about design in general.
And perhaps I am a little bit (ahem) enthusiastic about them.
Best wishes
Michael Storer
my boat pages
Old 05-02-2008, 11:21 PM
I think all the truly gifted designers have employed aesthetically wonderful lines and shapes, which proved to be cleverly engineered structures, fitting the function element of the formula.
I do take exception to function for function sake and letting things fall where they may visually. If this were not the case, we all would be building Bolger Bricks (or PD Racers Michael, which to me look like home made concrete mixing tubs) and couldn't care a lick about a Matincus Pea Pod or Rangeley boat as it glides past our view.
I'm an admirer of many Bolger designs, including some of the box boats that seem to be children only a mother could love visually. The brilliant design skills that make most of these boats perform so well (they'd better considering their looks) are noticed in me, but they could have been pretty also.
I work hard to get a sheer just right for the type I'm working on, though it may bear little in the performance envelope of the craft, I have to be proud it looks fine sitting on her marks come launch day. Maybe this is vanity, but I think you can have both and the better among us seem to do this much more often, compared to hacks like me, who might get lucky every once and a while a wiggle into a pretty bow profile by accident.
If L. Francis's "Ticonderoga" had a ugly reversed sheer, but still the enviable racing career she piled up, would she still be intact? I think she would have been left to die or broken up. I suspect all yachts would be broken up for their equipment, metals, etc. in favor of the latest butt ugly, though especially functional creation.
I for one, am quite glad it's difficult to design beautiful and functional craft. I think separating the gilded and functional, from the mundane and exceptionally functional is a worth while goal. I hope to live long enough to draw up something as spectacular a sight as "Big Ti" on a reach, rail washed and crew drinking wine.
Old 05-03-2008, 01:07 AM
BOATMIK's Avatar
Rep: 190 Posts: 273
Howdy PAR,
I think you would know with more certainty than me, but I seem to remember that everyone thought of the big T as a "bit of old hat" and "too old fashioned" by the racing crowd in the era in which she was launched.
By then everyone was considering S&S, Finisterre etc as the way to go. So because they did not realise that their aesthetic sense was a cultural adaptation they were never able to see the real function of the boat.
(actually they thought Finisterre wouldn't go either - "a fat centreboarder, had Olin been listening to Rod playing the Accordion for too long)
They didn't understand Ti's Ketch rig at all either. "they don't go windward".
So she is a great example of how the ratios and relationships are the things that give you function and everyone makes mistakes when they think they understand something from the appearance of the boat.
Also L. Francis is a good choice. One of my favourite boats - his 1929 "Live Yankee" in the R-class drove a 18 wheeled truck through the rating rules of that time (that had been thought up by his dad!). Flat sheer, heavily radiussed deck edge, aircraft construction horrified those who were used to conventional counter sterns and graceful sheers.
But Live Yankee now looks as modern as a 1928 Marcel Breuer chair.
Looks like it was designed yesterday
So I think your example of Ti and its designer supports my point.
Just because it does or doesn't "look right" doesn't mean that it works well.
And thanks for bringing up my version of the PDRacer. The fastest sailing concrete mixing tubs in the universe!!!! You should have seen all the guys tweaking ropes in their lovely Oughtred designed dinghies and yachts when I (and Ted in his boat) sailed round them in light winds and flat water at the Stansbury Wooden Boat Festival last weekend.
(The oughtred boats are very good sailers - but the PDR just hit the right bunch of conditions to be a lot better - on average the PDR would be a lot slower because it is shorter).
PAR, You know I have a good aesthetic eye - and also know I am restricted from doing anything particularly pretty by the PDRacer class rules.
Because they are a box people think they cannot sail. But because the ratios and relationships are right in my version their performance is very good in spite of the rule restrictions.
Don't get me wrong - I love Ticonderoga, I love Oughtred boats (I like PAR's boats too). But I evaluate the aesthetics quite separately from the function.
Now if the designer gets the two non related factors of correct function and appropriate aesthetics then that is the very best thing of all.
Luckily because they are independent they are also non exclusive - so it is possible to have both together.
However if I did have to choose ... I am very clear which way I would go ... and I know that everyone reading this would be forced to make the same decision.
Best wishes
Michael Storer
my boat pages
Old 05-03-2008, 03:42 PM
Michael, I think we're saying the same things, just going about it differently.
My contention is though she didn't fit conventions, Big Ti kicked serious butt, for many years on the course. All of the would be "experts" predicted her quick conversion to fractional sloop and dramatically increased area, but she just slide by, crossing line after line with the honors.
Finisterre and Live Yankee are also good examples for this debate. All of the above mentioned where fine looking yachts, who's form exceeded expected function. These are the hallmarks of great designers, making a beautiful thing do beautiful things.
Did they need to be lovely, nope, but I'm damn glad they were. You're correct in that if it doesn't look right it doesn't mean it can't perform well. I do wish that PD Racer was a more stylish concrete mixing tub, but it does offer modest performance for what it is.
Given the choice I want both the aesthetic and good functionality. Depending on how much penalty I must pay for these looks issues, I suspect most will error toward the pretty slug, then the ugly butterfly. If you have to be seen, in something that's getting it's butt kicked, they you should look good doing so I guess. So, this is where we differ. Maybe it's because I had a good looking sister and defended her honor, much to the regret of a few boyfriends, that would have likely preferred she was a bit faster.
deck, camber and sheer.... how to?!? yacht picasso Software 2 07-11-2007 04:02 AM
Question on reverse sheer Capt. Bill11 Boat Design 21 02-27-2006 07:06 PM
Fasteners as well as epoxy at sheer/deck joint? bjl_sailor Wooden Boat Building and Restoration 3 05-26-2005 07:47 PM
