http://www.yanmarmarine.com/theme/ya...t/3JH5E_HR.pdf http://www.yanmarmarine.com/theme/ya...t/6BY2-220.pdf When do you expect to get all these troubles of low load? How do 200 hp car diesels survive 500 000 km (at least 10 000 hours) without any of these problems and also provide extra heat to warm up the car? Only 20-30 hp is needed for maximum legal highway speeds on normal cars. |
| "When do you expect to get all these troubles of low load? " How do 200 hp car diesels survive 500 000 km (at least 10 000 hours) without any of these problems and also provide extra heat to warm up the car? " "Only 20-30 hp is needed for maximum legal highway speeds on normal cars." Cars frequently are called to accelerate , few will run hundreds of miles or hours at low load. Larger industrial sourced diesels are matched to their loads frequently 90% of rated RPM with 80% of rated load. That car engine with 80% of its rated load might not last 300 hours. Car engines NEED to be at 30 hp for much of their lives. FF |
Please learn to quote!!! It is a pita to read your contribution here. (apart from the fact, that it rarely is a pleasure) Regards Richard |
| " Is the Quote mark that is commonly understood in the English using world. FF |
However, there are many reasons that semi-displacement hulls are still popular, and owner's quite happy with their performance, at displacement speeds, including:
Therefore, you may read the inaccurate but perfectly applicable remarks that semi-displacement hull forms are fine at displacement speeds, because twice as much of a little is no big deal when compared to 5 times as much of a lot. In other words, the advantage of a displacement hull form is a small amount of money at displacement speeds. The advantage of a semi-displacement hull form at 1.5x hull speed is a LARGE amount of money. The cross over point is hull speed: 0.4 Fn or 1.34 SL. Below that, designs with the transom clear of the water and round bottoms are twice as efficient as other designs. Between 0.4 Fn and about 1 Fn (or 1.34 SL to about 3 SL) the semi displacement hull has an advantage over planing hulls that starts at about 25-30% and diminishes to zero at about Fn of 1. Published sea trials should of course be viewed somewhat skeptically, but tend to show that there is no real difference in semi-planing and planing hull forms. Sounds like displacement hulls are a waste of time, right? Well, actually they are really good if you always go slower than hull speed. You may get 5 nmpg rather than 2.5 nmpg. Won't notice this on a weekend, but if you take a month or longer for a cruise, it adds up to a significant savings. Quote:
Lots of good reasons to have those old mechanical diesels, but efficiency at widely different loads ain't one of them.
__________________ David Smyth |
Planing hull form (=prismatic hulls) can have very different resistance at the semi-displacement region depending on the hull form and weight distribution. I guess you can come close to semi-displacement hulls, but then the boat will not work well at higher speeds. |
| "Lots of good reasons to have those old mechanical diesels, but efficiency at widely different loads ain't one of them." True enough , but most full displacement cruisers will match the engine and load , so except for docking or some "no wake zone" an old repairable mechanical engine will be safer and cheaper to operate . It doesn't take many $5000 to $10,000 control boxes or sets of $1000 injectors to make up for 5 decades of "inefficient" cruising. The ability to start after being near a thunderstorm? PRICELESS! FF |
Can you be more specific about the hull characteristics involved in the comparision you make above. By semi-displacment hull are you refering to a "trawler" style yacht or one similar to Nigel Irens efficient designs? Do you mean to imply that a semi-displacement hull uses about the same fuel as a planing hull at displacement speeds? Also, where can I find the data? |
| There is no clear delineation between semi displacement and displacement hulls where one can simply provide data. You can if you want, make a distinction between semi displacement speeds and displacement speeds by choosing something like theoretical hull speed as the cut off but that still does not translate into data on hulls. Whether a boat acts as a semi displacement hull or a displacement hull has to do with the shape of the underwater lines of the boat, the displacement and overall dimensions. There is still a bit of an artform in designing boats when it comes to underwater lines. I think the easiest way to find out if a boat is semi or full is to simply ask the designer or read what his intent was. The worst place to find out is to ask a broker. There are some things that can be said about either hull type. One is that you will pay a bigger penalty in overall costs trying to take a full displacement hull into the semi displacement territory than you will taking a semi displacement hull into the displacement territory. Either way, you pay a penalty and must decide which poision you will take. For most people, semi displacement is a better tradeoff. |
| Semi-Displacement? | We're Here | Boat Design | 61 | 03-20-2011 05:37 PM |
| Displacement or Semi-Displacement Hull | waynep | Boat Design | 24 | 10-05-2010 09:01 AM |
| Displacement/Semi/Planing | Hotel Lima | Boat Design | 10 | 09-28-2007 12:41 AM |
| Increasing speed w/ semi-displacement hull | 67-LS1 | Boat Design | 17 | 12-11-2005 10:32 AM |
| Semi-planing vs semi-displacement | WayGray | Boat Design | 5 | 05-28-2003 10:21 AM |
