  #31
Old 01-03-2010, 09:19 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Anything specific? - no offence, but I think "not feasible" has been said about every new thing that has ever been made.
You are absolutely right. The other problem is to get someone gutsy enough to actually do it and test it. Most just want to critisize from their chair and pesrpective.
Regards
Fanie
Water ! Just gimme water !
  #32
Old 01-03-2010, 09:30 AM
Itchy&Scratchy's Avatar
Itchy&Scratchy Itchy&Scratchy is offline
Rep: 117 Posts: 141
If they persist with these massive hydraulic swing keels -that keep on falling off, a mono is as dangerous as a multi.
I like both so not taking sides on this one, just watching.
Im working on my second million.........I gave up on the first!
  #33
Old 01-03-2010, 11:02 AM
jonr jonr is offline
Rep: 34 Posts: 246
I wonder why they cant the keel instead of the mast? Either one will help keep the sail upright.
  #34
Old 01-03-2010, 11:10 AM
G8R G8R is offline
turd
Rep: 22 Posts: 8
I think it’s a good Idea, sort of like the pedal of a bicycle rotates around the shaft. I just might give it a try, and I would think that you would have to run the center beam through the full length of the central hull. I like it when people think out side the box!
  #35
Old 01-03-2010, 11:18 AM
Rep: 117 Posts: 141
As far as I know they cant the keels so that they can overload the rigs for maximum power imput.
I'm wondering if this will just be a fad, although its what? about ten years now they've been using these things in earnest and they are still falling off, or the rams blowing up etc. I am wondering how long theyll perservere with them. Maybe a designer of race boats will come along and let us know the benefits behind them.
I would be interested to know how much more loading is exerted on a boat with; as opposed to same size boat without a canting keel.
And
How much extra reinforcement is put into building a boat with a canting keel? apart from the obvious keel area.
Anybody in that game?
Justin
  #36
Old 01-03-2010, 11:56 AM
kim s kim s is offline
Rep: 42 Posts: 70
self righting mutihull
I do believe that some one is trying to start up a mini transat for multihull.
Part of the brief for the design,is it must be rightable (not sure thats good english)without outside assistance.
The one idea I saw was the outerfloats being able to move through 180 deg vertically and also the mast has releasing rigging to assist the turning as well.
As far as safety is concernd, i will just sit smuggly back with my beer staying where I put it, knowing that I will be in port tied up and safe long before the others arrive. I can be in before them when bad weather is on its way,
Mono hulls might be more "Sea Kindly". They have to be as they are going to out there a flippin long time.
Kim
Self-righting multihulls. How ? xarax Sailboats 45 12-23-2010 09:10 PM
self righting aiix Sailboats 24 08-28-2009 08:03 PM
Righting Moment Stevens47 Stability 2 04-23-2008 09:37 AM
Self Righting Systems kach22i Boat Design 2 02-25-2007 07:47 AM
Self Righting Rig Wardi Sailboats 14 06-29-2005 01:03 PM
